Old 10-25-2009, 11:25 AM
stk2008 is on a distinguished road
15mm ally plate
hi all sorry didebt know if this Q should go in here or not but any ways.
ive just got a plate of ally its
15mm thick
1025mm long
773mm wide
its going on me cnc as the bed base i intend to fit it with 10mm bolts at both ends it will have a sheet of ply ontop as the spoil board.
my Q is i intend to have it unsupported in the middle is this a good idea? its a hefty bit of ally ive been told it holds a tolernace of 0.001" will it bend over time?.
cheers all.
Old 10-25-2009, 03:07 PM
hemsworthlad is on a distinguished road
Hi Stk,
I,m no expert on this but i,m sure it will bend.
The reason i say this is because I cut my gantry end plates out of a piece about the same size, so going on that i think it would bend.
I suppose a lot will depend on what you intend to put on it and what tolerances you intend to work. If it,s just wood and the load is spread then no probs i would think, but if your putting engine blocks on it the thats another story!!
Easy way to tell would be too support both ends put dial gauge on it in the middle and then load it with something a bit heavier than what you intend to cut.. . . .I think you might be surprised how much it moves.
It,s an easy fix thou, just add a brace down the centre on the underside. . . Simp-pills. . :-)
Cheers
Dean.
Old 10-26-2009, 10:22 AM
jsheerin's Avatar
jsheerin is on a distinguished road
It won't bend over time, but it will deflect depending on how you support it and what the loading is. The math to calculate how much it will deflect is a bit involved, but here's a link if you'd like to try:
http://elib.mi.sanu.ac.rs/files/journals/publ/18/1.pdf
Otherwise, just try it and add the middle brace if necessary.
Old 10-27-2009, 12:42 PM
ok cheers for the replys all i will just throw 3 bits of 1" box section under it one on each end and one in middle.
cheers for input all.
Solid Carbon Fiber 15mm rods ? twocik General Metalwork Discussion 18 01-28-2009 04:17 AM
Cutting T-Slots in Ally. Advice please ImanCarrot General Metalwork Discussion 6 12-05-2008 02:42 AM
Four Carriages on Two 15mm Rails or a Single Carriage on a Single 45mm Rail ??? joprinz Linear and Rotary Motion 12 10-07-2008 06:08 AM
How do i stop stringing on ally Icehole General Metalwork Discussion 2 03-21-2008 04:55 PM
Anyone have a file for scale ally wheel designs chola G-Code Programing 0 02-10-2007 02:14 AM
