Old 10-23-2009, 08:09 PM
m8kingit is on a distinguished road
x axis only runs in one direction PLEASE HELP
I recently disassemebeled my machine to move it. i disxconnected the axis by removing the splices between the controller and the mill. However now that i have reconnected everyhting, my x axis will only travel in one direction. i've had this happen before, but i can'tr remember what the problem was. could it be software related, i'm using mach3. I'm using the gc11 board from cnc 4pc.
I does show it sending a signal according to the lights on the bob. could i have a broken wire or connection.
i think i remember there being a setting in the software that would change this, but i'm not sure what the problem was the last time.
Please help , all suggestions considered.
Mark
Old 10-25-2009, 11:05 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Think about what you changed / disconnected. Unless something came loose while moving, the problem is likely where you disconnected things. Unless you changed to a new computer, reinstalled software, etc., that is not likely the problem.
If that doesn't help, what type of motor and motor drives are you using? If steppers, look at the direction line to the motor drive.
Old 10-25-2009, 11:42 AM
FandZ's Avatar
FandZ is on a distinguished road
I had this happen before too, my problem was the wire in the db9 terminal came unsoldered. Don't know if you are useing a db9 cable or what but if the software settings haven't changed, I'd look at the wiring first.
Old 10-25-2009, 11:53 AM
Nothing has changed. The wires that were disconnected were color coded, so there is no way they are reconnected incorrectly. My guess is that if it was a connection , there would have to be two wires interconnected togtether to get the same direction when trying to jog another.
i didn't change computers either.
Need Help!- 4th axis G1 runs too slow slowbob Mach Mill 11 04-18-2009 12:37 AM
Need Help!- Camsoft controlX axis growing while the machine runs jguerrera CamSoft Products 3 10-13-2008 12:43 PM
Need Help!- MOTOR DIRECTION CHANGE, RUNS RUFF. Inivator Mach Software (ArtSoft software) 1 07-31-2008 01:19 PM
x axis will only move one direction CATCH22 Mach Mill 2 12-16-2007 08:53 PM
Need Direction on 4th 5th? axis program Cappy GibbsCAM 3 04-20-2007 07:20 PM
