Old 10-23-2009, 02:32 AM
crashswiftly is on a distinguished road
Talking I am FINALLY building One! help....LOL
Hi All,
I am building my first CNC machine and am about 80% complete with the structure. I need to start getting my thoughts together for the electronics to drive everything and need some advise on a complete electronics package. In my researching I have found a bunch of individual components and u-build boards but I would like to ask for some opinions on buying a complete plug and play setup. I am not electronic savy enough to want to try to assymble a board from scratch so the hobby cnc stuff is out. Are there any good packages available that include ALL the electronics needed minus computer.
My machine is mdf using the angled alluminum and skate bearing design and has approximately 20" x 40" cutting area. I want to use the machine to make relief carvings in cabinet doors and for building fire place mantels with carvings of wildlife scapes etc. I do not plan on any pcb milling or any type of metal to be cut.
What size stepper would be best for this application? I see people using anywhere from about 200 to 600 oz motors and don't know which to use.
Any help is GREATLY appriciated. I have been toying with the idea of building a DIY cnc for over a year now and finally got the time to build.
on the software end of things. i am planning on running mach 3, V-carve, CamBam and ? suggestions
thanks for your time and thoughts!
crash
Old 10-23-2009, 05:33 AM
Been looking around and found the Gecko G540 ... this would take care of the drivers and breakout board and then found 387 oz steppers sold by Keling for 49.00 usd each. the info page states these steppers are correct for use with the G540. what else am I needing besides these 2 items? I assume I will need a power supply to connect to the G540??
sory for dumb questions... I'll get this figured out soon enough...
Old 10-23-2009, 08:08 AM
ger21's Avatar
Yes, power supply. You don't need a breakout board with the G540, though. keling sells a complete kit with power supply, G540, and steppers.
Old 10-23-2009, 03:26 PM
leggazoid is on a distinguished road
If you buy the steppers from www.cncrouterparts.com they come pre-wired with connector for G540 for $52.
12 foot extension cables are also available.
Old 10-23-2009, 11:03 PM
Thank you BOTH for the replies.
I just put the items on my christmas wish list my wife demanded from me due Nov 1!
Going with the g540 and prewired steppers along with the powersupply and cables from fineline. Now all thats left is the software WOOT!!!
looking to go with mach 3 and CamBam and then V-Carve.
Any other software suggestions/recommendations??
I finished the machine tonight and all that's left is the electronics....man come on Santa!!!!!!
thanks again!
crash
Old 10-24-2009, 01:42 AM
FandZ's Avatar
FandZ is on a distinguished road
On the software front I really like Meshcam and cut2d even though I've only tried the demo's. I like cut 3d too but I felt like I had more control with meshcam. For cad I use either Google sketchup with a plug in to get dxf files or an old copy of solid works that I have. I am useing the free version of cambam and while I'm finding it workable, I'm just not enjoying it. But it's free so what the heck am I complaining about.
Old 10-24-2009, 03:18 AM
i'll look into meshcam, not heard of it till now...i have been playing around with cambam seems easy...
Old 10-24-2009, 10:08 AM
FandZ's Avatar
In the end you probably going to want one 2d cam program and one 3d. They each have their purposes. What will you be useing to draw up your designs?
Old 10-25-2009, 02:32 AM
good question, I use paint shop pro to make designs but never thought about if this can be used into cnc machining... the 3d progs i have in mind are photo v carve and v carve pro... 2d I have been playing around with the free trial of CamBam and don't know if i like it or not yet.
looking up mechcam tonight to check it out....
Old 10-25-2009, 07:00 AM
epineh is on a distinguished road
Something to look at for the CAD side of things is ProgeCAD, it is a free download that is basically exactly the same as Autocad, you have to register online but it doesn't cost anything, I use it but only for 2D drawings, it won't do 3D. Not a problem for me as most things I need it for it works well.
Russell.
Old 10-25-2009, 07:16 AM
ger21's Avatar
Unless it has vactor drawing tools and can export .dxf files ( I don't think so), PSP won't be usable for CNC.
Photo V-Carve and V-Carve Pro are not considered 3D programs. Photo V-Carve is a very specialized software that basicaly does one thing. Photos.
V-Carve Pro is a 2D CAM program, with drawing tools and V-Carving. The drawing tools are quite good in it, and many people use it for all their design work as well as CAM.
Another free CAD program is DoubleCAD, http://www.doublecad.com/Products/Do...0/Default.aspx
With MeshCAM, you'll need a 3D CAD or modeling program to create your 3D models, unless you plan on purchasing them.
  #12   Ban this user!
Old 10-25-2009, 11:39 AM
FandZ's Avatar
Right now I'm useing the free version of google sketchup, exporting the models as dxf with a plugin, and then useing the free version of cam bam to get my gcode. I'm actually cutting out my parts for my next cnc as we speak. The great thing about sketchup is there are a ton of free tutorials on youtube to get you designing quickly. That's my biggest gripe with all cad programs. You have to fork over a great chunk of change for the program and then spend a lot more for the tutorials or a class.
A free3d cam program is freemill. It's very limited in the types of toolpaths it creates but it is useful.
MY X4 PLUS IS HERE FINALLY! Gregory_C Syil Products 5 06-14-2008 01:15 AM
Finally! MrWild LinuxCNC (formerly EMC2) 2 05-12-2007 07:42 PM
Yep-Building a new Machine. Finally! vacpress DIY-CNC Router Table Machines 12 02-28-2007 02:18 PM
This Husker finally started building! nuplowboy CNC Wood Router Project Log 49 10-03-2005 09:13 PM
I finally started building! chuckknigh DIY-CNC Router Table Machines 16 07-10-2003 08:12 AM
