Old 10-22-2009, 02:11 PM
joprinz is on a distinguished road
Arrow Best location to mount Racks on a 3m Long Axis?
I'm designing a 3m x 2m CNC Router. Considering the length of the axis, most advices I get are to go for a Rack n Pinion drive for X and Y Axis. I am using Linear Guide rails (20mm) with 4 Carriages per Axis. I have also found 1.5 Moduli Racks n matching 1.5 Moduli 20 tooth Pinions.
However I have the following doubts:
1: What will be the Best location to mount the Racks? I intend to go with One Rack per Axis. But I hear mounting on one side of the axis could cause racking. Is it a common problem even if we are using Linear Guideways? if so How bad will it be?
2: I could redesign the table in such a way that I could mount the Rack in the middle of the table underneath the table top (similar to what we do for Ball Screws). Is this a good Option?
2: Do All commercial long axis CNC Routers use two Racks per Axis?
Please Advice!
Joe
X2 Z-Axis Motor Mount SSfab Benchtop Machines 13 01-13-2009 03:28 PM
Question RE Y-Axis Ballnut Mount BobWarfield Industrial Hobbies (Support forum) 8 08-25-2008 12:12 AM
Jet JMD-15 Y axis DRO Mount tkoden Benchtop Machines 1 02-14-2008 06:36 PM
Gantry X-axis mounting location aaron800 Linear and Rotary Motion 3 02-27-2007 12:29 PM
4th axis head mount rovingmind Open Source CNC Machine Designs 19 01-21-2007 10:15 AM
