Old 10-19-2009, 07:59 PM
murray is on a distinguished road
Lightbulb New Design
Hello all,
I have started to design a new cnc machine. It is going to be made out of mdf. It is based on the FireBall CNC. It will have a working area of roughly 12 by 12. The sides and bottoms will be held together with length of threaded rod. I have designed the gantry so far in sketch-up. I plan on cutting it out on the large cnc router at my school.
I have attached a few images below and will upload the sketchup file.
Please tell me where it needs improvement/strength.
ID:	91512   Click image for larger version
Visit my website at http://colvins.ca
"Remember that duct tape takes over when skill leaves off!"
Old 10-19-2009, 10:14 PM
jsheerin's Avatar
jsheerin is on a distinguished road
It looks like you're planning on using unsupported linear rails for the Y axis? If so, be aware that these will deflect more than if they were supported. How much and whether or not the deflection is acceptable for your design depends on all the details.
Old 10-30-2009, 12:07 AM
abomb55076's Avatar
abomb55076 is on a distinguished road
Make sure you get the gantry as rigid as you can. The more robust it is, the more accurate it will be and the better cuts you will get.
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
New to CNC. Need help with design. jfmonod DIY-CNC Router Table Machines 3 09-03-2011 01:29 PM
New Machine Design book from Alexander Slocum (of Precision Machine Design) toastydeath General Metal Working Machines 10 11-25-2009 10:37 AM
design grad project: new breed of CNC design, need input nicanor76 DIY-CNC Router Table Machines 11 09-22-2009 04:53 PM
Need Design Help justCNCit Linear and Rotary Motion 5 07-24-2008 10:27 PM
Finding Engineering Design Software For Automatic Machine Design hellokitty General CAM Discussion 0 01-06-2008 12:39 AM
