Old 10-18-2009, 11:23 PM
aviatorskate's Avatar
aviatorskate is on a distinguished road
Delrin Lubrication
I am using Delrin Nuts on my lead screws, does delrin need lubrication and if so, what type ?
Craig
Old 10-19-2009, 12:40 AM
CarveOne is on a distinguished road
Craig
Dupont Teflon Multi-Use Dry, Wax Lubricant from Lowes works well and is recommended by CNC Zoners for ACME rods and DumpsterCNC nuts. I have Dow Corning 321 Dry Film Lubricant and some brand of garage door dry film lubricant that works fine also. All of these are in spray cans. These sprays will evaporate and leave a film that doesn't turn into a greasy goo after dust gets mixed with it.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 10-19-2009, 01:30 AM
Smile
Old 10-19-2009, 08:11 AM
ger21's Avatar
I use air tool oil. Just a few drops, then wipe off the excess after running the machine back and forth a few times. I find that it worked better for me than dry film lubrication. But it will attract dust.
J Head Lubrication pearldiver Bridgeport and Hardinge Mills 0 07-11-2009 01:10 AM
MM lubrication concern cn00728 Haas Mills 2 10-02-2007 12:13 AM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 01:13 AM
lubrication question???? Cutloose Linear and Rotary Motion 2 10-14-2006 03:20 AM
Lubrication BeerFizz Benchtop Machines 5 11-09-2005 06:25 PM
