Old 10-18-2009, 03:36 PM
bigz1's Avatar
bigz1 is on a distinguished road
Router Runout?
Just machined a cylinder 120 diameter by 30mm thick in MDF. Unfortunately it sides have a taper making it a truncated cone is this due to router runout? The piece widens the lower the tool cut. Taper is equal all the way round.
Old 10-18-2009, 04:30 PM
ger21's Avatar
How much is the taper? I'd say it's unlikely due to runout, and more likely from machine flex. Is it consistent all the way around?
Old 10-18-2009, 05:48 PM
bigz1's Avatar
Yes its consistent all the way around. Approx deviation in diameter is 0.5mm. The bottom of the cut is more accurate. Normally I use a slight increase to the diameter of the tool for shallow cuts but I wasn't too concerned about the tolerance on this piece. But would like to nail this problem for future work.
Old 10-18-2009, 06:44 PM
stevespo is on a distinguished road
Use the largest diameter bit that makes sense for the project. I'd probably use a .25" upcut. Take lighter cuts and slow down your feed rate, until the taper disappears. Let us know what you're using for tooling, feedrate, spindle speed, etc.
You could also try a multi-step roughing cycle, leaving the part .010" oversized. Then come in with a single full depth pass to bring it to final dimension. You'll need something with a cutting edge at least 30mm tall. These are all worth a try.
If your router does have some runout, you might discover you have to enlarge the part slightly (or alter the toolpath) to compensate for a .25" cutter actually removing .252" worth of material. It all depends on what kind of accuracy you need to achieve.
Steve
What is Runout ToyMaker FAQ of CNC Machine building 7 01-08-2012 08:15 AM
Need Help!- runout gregoryblaine General Metal Working Machines 1 08-11-2009 11:55 PM
Dremel Runout ajayre DIY-CNC Router Table Machines 8 06-23-2008 06:53 PM
Improve your router runout with precision bearings? biomed_eng DIY-CNC Router Table Machines 24 10-28-2006 06:50 PM
Runout grantmi1 Hard and High Speed Machining 6 06-12-2003 03:22 PM
