Old 10-17-2009, 09:44 PM
rlwoodjr is on a distinguished road
This will be the 5th one
I always seem to gather more stuff than I need when I get into a hobby so I thought I will build another one...since I have most of the stuff I need.
Cutting size:
X 15", Y 12", and Z 3 "
Threaded rods 5/8-8 ACME threaded rod
Nema 34 (half-heights), 100 ounce/in steppers
5/8" ground and polished rods on bronze bushings.
Some type of dremel sized spindle
Aluminum construction with wood table
ID:	91362   Click image for larger version
ID:	91363   Click image for larger version
Old 10-19-2009, 01:31 PM
wriley is on a distinguished road
Looks good. I'm looking forward to the build pictures.
William Riley
http://workbench.freetcp.com/
Old 10-27-2009, 09:09 PM
Some progress. I cut the rods to length, drilled and tapped the ends (10-32)
Name:	small rods.JPG‎
Old 10-27-2009, 10:56 PM
FandZ's Avatar
FandZ is on a distinguished road
May I ask where you got your bushings and rails from? Those look to be thicker than the normal bushings I've seen.
Old 10-28-2009, 08:55 PM
I bought them on eBay. I buy most of my stuff there. They are 5/8" ID and 1" OD and are 2" long.
Old 11-08-2009, 08:07 PM
A little progress. I was hoping to have it done well before Christmas. I think I might sell this one on EBay.
Next I will make the gantry sides....
Old 11-08-2009, 11:07 PM
FandZ's Avatar
Looks pretty and beefy at the same time. Since you may be selling it, you should round out the front corners of the top Z axis plate. The one holding the z axis rails, like you did with your spindle holder. Speaking of spindles, what is that you have mounted there? Looks interesting.
Old 11-08-2009, 11:29 PM
Arquibaldo is an unknown quantity at this point
beautiful
rlwoodjr:
Congratulations - beautiful workmanship.
Any chance of disclosure of the drawings?
What kind of nuts are you planning to use on those 5/8-8 ACME threaded rods?
Aren't you worried about gantry racking, with a single central screw?
Like FandZ, I'm also very interested in knowing more about that spindle...
Nelson
Old 11-09-2009, 06:07 PM
Thanks. Yes, I still will need to sand and break corners. The spindle is one I found on EBay. You can find them listed under "flexible shaft"
Old 11-09-2009, 06:13 PM
Originally Posted by Arquibaldo View Post
rlwoodjr:
Nelson
Thanks, I actually do not have drawings. I modelled it in ProE, I just pull up each piece when I am making it.
I make my own nuts out of the UHMWPE to use with the 5/8-8 ACME thread.
Since the machine is small I am not worried about racking. I have built a small MDF like this one. I did not notice any racking.
  #11   Ban this user!
Old 11-09-2009, 06:15 PM
Close-up of the spindle
  #12   Ban this user!
Old 11-15-2009, 07:12 AM
A little progress....
Name:	Making piece.jpg‎
ID:	93388   Click image for larger version
