This isn't much, just a pile of hardware, but you have to start somewhere. ![]() I am going to build a 2' x 4' CNC router based on the http://buildyourcnc.com/ design. The plan is to cut wood, acrylic and possibly very thin (25 and 50 mil) aluminum. At the very least it will be a learning experience and I can cut parts for the inevitable next machine. More to come.
__________________ William Riley http://workbench.freetcp.com/ |
Yes, it is aluminum angle for the bearings. I have not heard of any wear problems but will look into it, thanks.
| For starters I am going with threaded rod. I want to get up and going cheap and then I can upgrade or build a new machine on down the road. 1/4-20 seems too flimsy so I am going to look at some of the bigger rod.
| Hi wriley I saw the bearings that he is using do not use that type ending in ZZ you want to have the same bearing # but ending in 2RS ZZ are only shielded, 2RS are rubber shielded/sealed & will keep the dust out better
__________________ Mactec54 |
#10
| mactec54, thanks for the info on the bearings. I assumed the rubber bearings were inferior to the steel shielded ones. 1/2 10 ACME rods can be had for 9$ per 6ft. http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32 You can also get the bolts for 1.69 each. http://www.use-enco.com/CGI/INSRIT I know people somehow use the bolts and a thrust bearing or two get near or 0 backlash instead of useing a derlin nut. I'm just not sure how the configuration is done. I went with a derlin nut myself. But my point is, it's cheap and something you could move to your next machine. Plus the speeds you'll get from 1/4 20 will be horrible. Just saying, it's cheap and superior. I'm running my X axis on aluminum. There is an obvious track where the bearing rolls but wear doesn't seem to be much of an issue. No Idea on how long they will last but I'm sure it's over a hundred hours of use. You'll just need to watch for swarf getting between your bearing and your rail. The aluminum will deform before the steel bearing does. Anyways looking forward to your build. |
| saleCNC laser engraving machine and CNC woodworking machine | zhangrui1588 | Laser Engraving & Cutting Machines | 3 | 05-08-2011 03:54 PM |
| Another machine rigid tapping (stepper machine) | samco | LinuxCNC (formerly EMC2) | 10 | 04-10-2009 07:21 PM |
| sell CNC Woodworking Machine,CNC Advertising Machine | zhangrui1588 | Product Announcements & Manufacturer News | 0 | 05-30-2008 08:43 AM |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 09:37 PM |
