  #13   Ban this user!
Old 10-15-2009, 12:08 AM
DanOSB is on a distinguished road
hmmm that cold air gun sounds like a perfect solution.. will look more into that..
  #14   Ban this user!
Old 10-15-2009, 03:34 PM
analogman is on a distinguished road
Cold air guns will require a large compressor and will up the noise factor - but will do the job.
  #15   Ban this user!
Old 10-15-2009, 05:30 PM
jeffery71 is on a distinguished road
I've been thinking about using some of the 1 inch thick Trex type decking they use on outside decks. (The plastic stuff) If you cut some datos on the bottum and then spaced them appart you would have a nice tslot table top. Just an idea.
Jeff T.
http://www.3dcarvestudio.com
ridges on spoilboard when surfacing Dan.antes Calibration & Measurement 8 12-15-2009 01:23 PM
Seal MDF spoilboard? analogman DIY-CNC Router Table Machines 14 07-02-2009 09:34 PM
SpoilBoard Surfacing barsam DIY-CNC Router Table Machines 1 01-05-2009 10:11 AM
Spoilboard - brand, availability Grant Nicholson Wood Working Tooling 5 11-26-2008 07:00 AM
spoilboard material lonesome dave General Material Machining Solutions 0 07-24-2007 08:55 AM
