Old 10-06-2009, 03:21 PM
YIORGJX is on a distinguished road
Easy to make cnc router '.skp' plan
Easy to make,but not at all pro...
x 27 cm
y 27 cm
z 7 cm
The .zip is a qoogle sketchup file.
Last edited by YIORGJX; 10-06-2009 at 03:40 PM. Reason: insert image and attache file
Old 10-30-2009, 01:12 AM
abomb55076's Avatar
abomb55076 is on a distinguished road
That looks pretty simple. Theres more information about diy cnc machines at www.homegrowncnc.com also.
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
Old 10-30-2009, 06:20 AM
CarveOne is on a distinguished road
I would recommend extending the two box tubes under the X axis rails out to the end of the rails. The cost is negligible and it doesn't leave the rails dangling unsupported. I would also recommend moving the leg assembly out to the end of the rails.
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
Old 10-31-2009, 02:46 AM
FandZ's Avatar
FandZ is on a distinguished road
Using just one bolt per side on your gantry will probably result in your gantry dipping back and forward. You could solve this by adding a cross beam underneath. With the drive screws, shouldn't you use 2 nuts to help fight backlash? The they are now I only think they could drive an axis in one direction.
I really digging on how you have your cutting tool mounted.
Revision 2 of FLA100-00, a full 2'x3' router table plan. solodex2151 DIY-CNC Router Table Machines 5 02-27-2009 12:40 PM
Plan to builld a CNC router bothunter DIY-CNC Router Table Machines 0 02-12-2008 06:51 PM
Plan for DIY Router jensn DIY-CNC Router Table Machines 5 01-27-2008 04:04 PM
grade 10 teacher needs easy plans for cnc router scottinwind DIY-CNC Router Table Machines 11 12-12-2007 01:09 PM
need help make the choice on what plan to use temler DIY-CNC Router Table Machines 3 03-18-2007 10:24 AM
