Old 10-05-2009, 11:12 PM
Jack000 is on a distinguished road
some design ideas
Hi guys
just playing around with some ideas for my next build. I like Joe's 4x4 and took some ideas from that, but I also wanted to try some of my own ideas.
The frame is made from 1 1/4 strut channel, the y supports are 3030 extrusions, and the gantry is mdf. The whole thing should have a working area of 4x4 and footprint of 5x6. The idea behind the mdf gantry is that I can just rout it out in 4 layers and glue the layers together for easy assembly. The hexagonal holes are to reduce weight while maintaining strength. The 3030 will be tapped and screws will hold it together with the mdf.
I'm having trouble designing with the v-groove wheels, since I haven't found any specs for the eccentric/concentric bushings. I need to know how far the wheels will stick out from the base with the bushings, but I'm a little fuzzy on how the mechanism works. How exactly does the eccentric bushing maintain the clamping force? Is it tapped on the inside?
thanks
ID:	90556   Click image for larger version
ID:	90557   Click image for larger version
ID:	90558   Click image for larger version
___________________________
www.carveit.ca
Old 10-06-2009, 07:48 PM
scotta is on a distinguished road
Check out Stock Drive Products, they even have CAD model downloads for most of their products including V-Groove wheels and bushings.
Pics of something I've been working on. Wheels and busings from Stock Drive Products CAD library
Scott
ID:	90602   Click image for larger version
Old 10-07-2009, 12:37 PM
hey, thanks! Their prices are a little high, but the models will be useful.
www.carveit.ca
Old 10-07-2009, 08:21 PM
Their price for bearings and bushings are high, got mine from VBX and will make my own bushings. Prices for belts and pulleys are good though.
Scott
New Machine Build- Desktop CNC Design Ideas bmsgaffer86 DIY-CNC Router Table Machines 5 08-03-2009 01:04 PM
off the wall nooobie design ideas project5k DIY-CNC Router Table Machines 87 11-17-2006 12:05 AM
need ideas on Y axis design toolbox82 Mechanical Calculations/Engineering Design 0 02-24-2006 08:40 PM
First Machine design - your ideas pls Moondog DIY-CNC Router Table Machines 7 07-03-2004 12:23 AM
My CNC links for design and ideas misterdj DIY-CNC Router Table Machines 0 03-10-2004 05:39 AM
