Old 10-05-2009, 01:05 PM
small_rcer is on a distinguished road
Looking for reliable drill or spindle for drilling wood
Good day all;
My client has had a Milwaukee professional drill running on his Phoenix Klein Mill hybrid. It has drilled about 34,000 holes in wood in the past 6 weeks. It just stopped!
Likely the brushes or something simple but it is an annoyance. Does anyone have experience with some spindle that can drill holes in wood but will live for more than 2 months?
Max drill bit is 15/32 but most holes are with 1/8th bit. Drill runs at 1200 rpm.
Will be putting a relay control from breakout box to shut off the drill after a part is finished, to reduce run time a bit. But on drilling cribbage boards it runs 1 hr 12 min to drill 745 holes and there cannot be much time saved by shutting off at end of cycle on way to home position.
Jim H
Drilling polycarbonate on drill press martinw Mechanical Calculations/Engineering Design 10 11-08-2007 09:45 PM
Drilling 27/64 with solid carbide drill bink General Metalwork Discussion 3 10-24-2007 10:59 PM
Drilling o1 drill rod Madbob9 General Metalwork Discussion 9 06-11-2007 11:24 PM
drilling codes, which software? I want to drill my pcb with my machine. NickLatech DIY-CNC Router Table Machines 1 03-16-2005 07:37 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 10:16 AM
