Old 10-02-2009, 01:02 AM
dhaddox is on a distinguished road
Z axis
I have an old 4x8 tracer oxy/acet burn machine that I am going to take out the tracing eye and replace with a router. I am going to leave the arm that sticks out off the side on there and use it as a cnc plasma cutter. The machine already has motors and rack gears but I am going to have to upgrade the motors. I am also going to have to make a z axis and was wondering how much travel the z axis should have? Also i am not sure about motor sizing on the x axis, I plan on using servos (1 each side) with about a 10:1 reduction. The axis moves easily but is pretty heavily built (about 750 lbs) , i would like to have around 500 ipm rapds. I am not sure what size motors it would require, any input would be appreciated. Thanks
Old 10-02-2009, 08:26 AM
ger21's Avatar
Figure out where the spindle needs to be when the shortest bit you'll use reaches the table. Go a small amount lower, and that's the bottom of the travel. Then, figure out how high it has to go so that your longest tool will clear the thickest workpiece that you'll be cutting. Add a little and that's the top of your travel.
Old 10-02-2009, 01:57 PM
jsheerin's Avatar
jsheerin is on a distinguished road
From my calculations, if you get motors that have around 3N*m of torque at 11krpm (assuming a 1" pitch diameter pinion), that would give you acceleration in the 50in/s^2 range and around 180lbf to cut with. I'm not real familiar with servos though, so I'm not sure if you can find one that turns that fast. If you didn't gear them that much, you'd need more torque but at lower rpm.
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 04:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 08:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 02:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 01:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
