  #13   Ban this user!
Old 01-02-2010, 12:00 PM
atwooddon is on a distinguished road
Danilom
Thanks for your reply about the X axis sagging under heavy load. Do you think that would be mostly solved by going to a larger X axis rod like 25mm? Also, I assume you meant the X axis was sagging under load, but not the Y Axis?
thanks again
Don
  #14   Ban this user!
Old 01-02-2010, 12:59 PM
danilom is on a distinguished road
Well if sag means the same as bend then that is what is happening but not from the static load (weight of gantry etc), its happening when the gantru and the Z axis are moving (rails and contruction are not siff enough) also when the router bit meets some resistance in going through the material, as I see its normal for unsupported rails . The thicker the better I would assume but the weight and price should be taken into consideration, as smaller diameter supported rails and open linear bearings are cheaper or the same price as unsported larger diameter linear bearings and shafts.
  #15   Ban this user!
Old 01-02-2010, 02:20 PM
Danilom
makes sense, I willcheck out the supported rail/bushing prices.
Don
  #16   Ban this user!
Old 01-03-2010, 01:28 AM
livingsouljd is on a distinguished road
Smile Estimating and Plans
I wanted to congratulate you on an impressive build. I am trying to convince the wife to let me try my hand at building one but so far am not having much luck at even etimating what it would cost to build one like this. Also, is this built on any certain plans? I am still searching for clear building plans. Any help you can give is greatly appreciated. Great job again!
  #17   Ban this user!
Old 05-15-2010, 05:38 PM
While ago I bought some engraving bits 0.2mm
I made a pcb for my new breakout board for another cnc that I have started to assemble (Mechmate)
machine did an excellent job pcb came out perfect and drilled too!
  #18   Ban this user!
Old 05-16-2010, 10:12 AM
sports.racer is on a distinguished road
That board looks great!
  #19   Ban this user!
Old 05-16-2010, 10:36 AM
stk2008 is on a distinguished road
holy crap that PCB looks awesome.
nice work maty all the work you have done looks nice and clean
Old 05-16-2010, 12:11 PM
ger21's Avatar
You better post a lot of pictures of the Mechmate build.
  #21   Ban this user!
Old 07-19-2011, 02:46 PM
Mechmate router, late review :)
Hello,
I have not been posting here for a while.
Things changed, and I must say its a doom or something. I see everyone here who builds his machine eventually builds another one and possibly LARGER one.
Small router is dismantled and the parts are likely to be put on a small mill I plan to add to my shop.
So it was same with me, the step forward was to build a Mechmate. With working area of 2800 x 2050 mm.
I am using a water cooled 2.2kW spindle with VFD, it really helps to have a good RPM control. Motors are NEMA34 ~6Nm and 5Amps with drives from Deitech 2M982 used on a 43V DC power supply.
Here are some photos of the finished build and some things I've done with it.
Mardus (MARic DUSan) is kind of a neighbor to me and his drives (Mardus Kreutz) helped a lot so his name appears on the machine. Drives were changed because I needed the bipolar torque, they were changed after 6 months of use so they stood quite well.
The plastic plates for reduction did not satisfy so I used the mechmate to make new ones out of some Alu.
Also spindle light:
Also made a pendant with Pokeys for Mach3.
And all sort of other things
No chatter at all, rack and pinion is a way to go for me.
Tags
ballscrew, mardus, mdf, router
Newbie- pre built X/Y Drools DIY-CNC Router Table Machines 0 03-29-2009 08:54 PM
How I built my CNC scheek DIY-CNC Router Table Machines 2 03-01-2007 06:58 AM
I built this on a VM-22 AMCjeepCJ Milltronics 14 02-27-2006 07:49 PM
Here is the DIY I built. ljoe1969 CNC Wood Router Project Log 4 02-28-2005 03:42 PM
Built it, need help using it! Lionclaw DIY-CNC Router Table Machines 7 01-12-2005 09:25 AM
