Hey guys, well got my machine running, and i cut a few parts that were not circles and everything seemed ok. I am cutting some circles out of pink foam, and on one side its 3.01 and then if you measure around it goes down to 2.95 in one spot or side. I am running antibacklash nuts on 1/2" acme rods, with .500" per rev travel, using 387oz motors, with a Gecko 540 drive, rapids are 120 ipm, and cutting speed is 50ipm in Mach 3. I am using a .25" spiral upcut bit, at about 18k rpm, which is the lowest my router will do. Anyone have any suggestions? Could i just be seeing a little racking on the X axis? My y axis is super solid, and my x has a slight wiggle. Or am i just asking too much for the resolution of my machine? I should be able to get a decent circle shouldn't I?? Thanks, Andy |
| Which axis is the 3.01, and which is the 2.95? Can you post a pic? It could be that the screws are slightly different, and you can adjust it by changing the steps/inch.
| Ok, here is a picture. The X is the front of the machine, and the X with the dots is the back, or the home position, and the Y is the home position in that axis. As you can see the X and Y directions are pretty close, but the egg shape happens basically in the corner of the cut. In the program the bit is plunging where the Y is and going clockwise around the circle, i tried several different feed rates and seemed like it did not do anything. Thanks for the help guys, its greatly appreciated. |
| I would check the antibacklash nuts for well... backlash. I bought 4 -1/2" 2 start 5 TPI from Dumpster and they all had backlash. I replaced them with some from Roton and now all is better and I can hold about 3 thou. |
| Are you using a single G2/G3 for the hole circle, or is it broken into smaller segments? How slow have you tried to cut it? Are you sure the X and Y axis are perpendicular to each other? If you cut a square, is it square?
| Well to start off with the sad news, i tried to cut a square, and it definately is NOT SQUARE! So i took a measuring tape, and sure enough when i move the Y-axis across the table it measures out differently between the bit and the end of the table, by about 3/8" so i moved all that and cut another circle, and now it is really close to being square. I will try and cut another circle and double check everything, as well i am going to check to make sure that when mach 3 is moving 1 inch, the router is moving exactly 1 inch. Thanks for the help guys Andy |
CarveOne
__________________ "A $1,000 electronic device will almost always protect a ten cent fuse." |
#10
| I think what he is saying, is that the Y axis is out of square by 3/8" from one end to the other. It is possible to have Mach3 compensate as the Y moves across the table. If you can't get it square, I can tell you how to do it.
#11
| Gerry, how would you change that in mach 3? I am still off by about 1/32" or maybe a little more between the 28 inches of travel i have right now. I am also thinking of purchasing some linear rail off ebay, and redoing my gantry. Thanks, Andy |
#12
| You use the formula functions. Are you saying the X changes as you move along the Y?
| Funny shaped Cam lobe | stevehuckss396 | I.C. Engines | 17 | 02-14-2010 06:02 PM |
| Need Help!- circles arent circles | xlr8r | DynaTorch | 3 | 01-18-2009 12:26 PM |
| Shaped Tools | patycoop | SolidCam | 3 | 02-10-2008 04:58 AM |
| Perfect shaped circles needed - Please help | organetic | DIY-CNC Router Table Machines | 1 | 05-03-2007 08:32 AM |
| Bending a U shaped | MBG | Bending, Forging,Extrusion... | 10 | 06-15-2006 12:27 PM |
