#13
| Correct, I think. As i cut in the Y direction, as it goes away from the home position it moves about 1/32" now in the negative X compared to where it started. After i found the 3/8" thing i was super not happy! I just ordered 2 46.5" linear igus rails, with 2 recirculating ball bearing carts for 90 a piece on ebay, so i think i am going to redo my gantry a little bit, but i want to use the current setup to make parts for the next one. |
#14
| In Mach3, under Funtion Cfg menu, choose Formulas. Check the enable box at the top left, and in the first box (f(x)=) enter: x+y*.0011 Close and restart Mach3, and it should work. As the Y axis moves positive, the X axis will slowly move to the positive direction to compensate. .0011 x 28inches = about 1/32". Note: It will not work while jogging, but it will adjust when using MDI or running g-code.
| Funny shaped Cam lobe | stevehuckss396 | I.C. Engines | 17 | 02-14-2010 05:02 PM |
| Need Help!- circles arent circles | xlr8r | DynaTorch | 3 | 01-18-2009 11:26 AM |
| Shaped Tools | patycoop | SolidCam | 3 | 02-10-2008 03:58 AM |
| Perfect shaped circles needed - Please help | organetic | DIY-CNC Router Table Machines | 1 | 05-03-2007 07:32 AM |
| Bending a U shaped | MBG | Bending, Forging,Extrusion... | 10 | 06-15-2006 11:27 AM |
