Hey all, This is mostly based off buildyourcnc.com cnc router tutorial. I'm curious if there are any problems with the idea, maybe something I overlooked. As you can see it's fairly small, but I will use it to machine small parts, as well as etch and drill pcb's. ![]() ![]() ![]() |
| Mount the motor and coupler outside the front or rear of the machine's base plate and use a longer lead screw to make use of more of the travel capability. You can put a sheet aluminum cover over the motor and coupler to keep dust and debris off of it if you wish to. For the gantry beam, a piece of 8020 extrusion would be much stiffer than a single layer of MDF. If not that, double the thickness of the beam with two layers of MDF for improved resistance to twisting under loads. CarveOne
__________________ "A $1,000 electronic device will almost always protect a ten cent fuse." |
| Perhaps a pipe or MDF piece that sits behind the Y carraige, parralel to the gantry rail, but not actually a rail. Last edited by marcll; 09-25-2009 at 05:52 PM. |
| SketchUp 2 Solidworks | chojin | Solidworks | 18 | 01-07-2012 07:07 PM |
| Sketchup success in CNC? | ZipSnipe | General CAM Discussion | 10 | 02-27-2011 10:59 AM |
| First CNC Idea Sketchup - What Do U Think? | Telly | DIY-CNC Router Table Machines | 11 | 05-02-2010 01:05 PM |
| SketchUp | rigrandy | General CAD Discussion | 2 | 09-18-2008 06:20 PM |
| Sketchup..... anyone using it | plane magic | General CNC (Mill and Lathe) Control Software (NC) | 5 | 03-15-2006 07:02 PM |
