| Im planning to cut, engrave or carve different kinds of soft to hard steel or metals such as aluminum, copper block, PC casing, etc. - what bits should I use for engraving carving and cutting? - what reminders should I consider for safety operations? - what are things needed for cutting engraving metals to prevent heat and blunting my cutting engraving tool bits? - any tips and tricks? any picture to share about the actual tool bits? Im using a 35,000 rpm 500watts power tool as my spindle not variable speed. I have done some wood working projects and planning to learn and experience about steels and metal cutting and engraving please help Last edited by guy2b1; 09-23-2009 at 06:58 PM. |
i mainly use no. 1 ,2, an 3 center drills for engraving 1/8 in. thick alum. it works great . i run about 30 in. per min. that way its very fast. an clean .no. 1 for fine line .up to no. 3 centerdrills for thicker lines . with very little tool wear . try it .it works good. |
| Engraving - Carving Photographs | Tony Mac | Vectric | 2 | 05-08-2011 04:40 PM |
| Engraving and Etching on Metals, Acrylics, Glass, Plastics in New York | bradpit | Engraving Machines | 0 | 08-29-2009 07:49 PM |
| Carving (engraving) on a Taig! | ecope | Taig Mills & Lathes | 0 | 05-27-2008 11:13 PM |
| Engraving and carving stone, I'm Confused | foamcutter | General Material Machining Solutions | 11 | 08-03-2006 08:54 AM |
| Image Engraving/Carving bits | Dman | DIY-CNC Router Table Machines | 1 | 04-16-2005 05:41 PM |
