Sorry mods if this is in the incorrect forum. Ok... I know what I want to do, but just don't know how to do it. And that is to build a 3 axis DIY CNC for acrylic. As I have no clue where to start, let alone even what questions to start, I would be grateful if someone could point me in the right direction. I don't need (at least for starters lol) a big machine, but maybe 24"x24" table size? Throw some Q's at me so I can start the R&D on this thing. About how much (yes I am sure it depends on some 'bells and whistles') would a table of this size cost? Thanks to all that can help and looking forward to any replies.
__________________ If you don't like it build it yourself |
| Start reading as much as you can here. How thick is the acrylic you want to cut?
Are you making one specific product, or a range of things? How big will the largest piece be? Are you doing 3d carving, or just cutting things out of sheet? Do you have a well-equipped shop to build things in, or is this a "kitchen table" project? Will you have a place to put this thing, once it's built, or is this going to live in the livingroom? How are you figuring on holding the material down while you're cutting it? Is speed of production important, or just getting it done eventually? Do you have enough money to buy a machine instead of building one? Have you ever tried cutting acrylic with a router, even by hand? Andrew Werby www.computersculpture.com
| Well i guess i have a few comments. I just finished my 3' x 5' table, and i bought some really nice components as far as motors and controllers. I was going to build a small table first, and although so far the biggest part i have machined out is only 6" x 4", i have plans to use the full 30" x 42" i have of travel right now. My comment would be to built it with a nice controller and motors, that way if you want to or when you upgrade to a larger machine, you can possibly reuse some stuff. You could do belt drive, or threaded rods for your movement, i liked the threaded rods, and the anti-backlash nuts work wonders. Andy |
| I'd do as Gerry suggests... but add that you should decide what material you'd like your machine to be constructed of. Then... do a Forum SEARCH with the TAGS that material might evoke. Example... Say you are leaning toward MDF with skate bearings for your linear components... CLICK on the SEARCH drop down menu in the header bar at the top of the page and enter... MDF, skate bearings in the text window and CLICK on TAG SEARCH just below the window. This will provide a bit of focus that otherwise without could overwhelm you. Lurk and learn... there's a tremendous amount of talent and info here...! Senna |
| Thanks everyone that has taken the time to reply. I am pretty much just diving into this so please bear with me on the noob Q's, though I am a fast learner. My replies will be in red
Any one get one of those plans and have good results from them? And if so, which site/one? Oh... though I could see this getting into other items such as wood, what would it take for lite aluminium, just a thought at least Keep'm coming
| Two years ago I don't think there were options others than build it yourself unless you had a large budget. Now there are two options that I would seriously give a hard look at. First there is the kit offered by finelineautomation. $1300.00 and all you need to add are electronics, a router, and a mount. Here is a link to the online store and a link to the thread. http://www.finelineautomation.com/st...g=Complete+Kit 2'x3' Free Router Plans - All Aluminum and Steel, Completely Bolt together They have some videos floating around of it routing aluminum. It's has a 2x3 cutting area. Next are the machines offered by modular cnc. They have a 12x11 one for only 350. http://modularcnc.flyingcart.com/ind...&pid=3&cat_id= I'd probably go with the modular cnc machine to learn on and to help me build a second larger machine later on. But I'm cheap and have a family to support. Building your own is enjoyable and challenging, I did it and am doing it again with the help of my current machine, but if they had these deals when I was building my 1st machine I wouldn't have done it. Why build when you could be useing? The ultimate goal is to use a cnc machine and not just build one. The average build is probably 3 months to a year. Some people spend a few years building theirs. Then once it's built you still have to contend with cad and cam, spindle speeds and cutters, and working all the kinks out of your machine. That is my 2c on the matter. No matter what though, you have a lot of reading to do |
| If you'd like to build it yourself, another site to check out is Patrick Hood-Daniel's machine at http://buildyourcnc.com/default.aspx I ordered the 4x8 kit and I'm almost done. I didn't know one darn thing about CNC before I started and this was a good route for me to go because: 1) I don't have a lot of money to spend 2) building from a kit is a great way to learn about the machine 3) I have a garage, some tools and some woodworking experience 4) Patrick's a GREAT resource for all those "dumb" questions that arise during the process I would agree with the folks who say there's a lot of work and studying to do if you're just starting out. I'd say the effort is quite comparable to the effort required to do well in college. There's just so many aspects of CNC'ing that all have to come together before you can even cut your first part. But that's what makes it fun and why you can charge good money for your work. -BrianB < Yeah doc, I'm having trouble sleeping. See, I'm building a CNC router in my garage and every time I try to relax, another new idea just pops into my head... > |
#10
| I would absolutely recommend cncrouterparts and finelineautomation solution. It's very elegant and easy to build with basic tools. I myself have built the cnc machine with their parts and I'm completely satisfied with its performance. You can see the machine in action on this forum some threads ago or on this site.
__________________ My DIY CNC router plans at www.8020CNC.com |
#11
| Hey thanks to all that have taken the time to reply. I am getting real close to know what I want to get, but I am not sure of the router to buy. What are some suggestions? If you can, provide Model numbers please. Just trying to compare at this time. Thanks once again.
#12
| I suggest the Hitachi M12VC -- it's a reasonably priced, quiet, variable speed router that I use on my machine. I'd love to help you with your machine, so feel free to PM me if I can help you out. Best regards, Ahren www.cncrouterparts.com |
| higher torque 5 start, vs lower torque 2 start | carvemylog | DIY-CNC Router Table Machines | 8 | 03-11-2009 11:44 PM |
| Arrow 750 Failed to start when I Push start Bottom in fornt of control ! | mte.jalal | Cincinnati CNC | 4 | 01-06-2009 11:20 AM |
| Newbie- one start or two start lead screw | Pinhead | DIY-CNC Router Table Machines | 5 | 11-22-2008 11:32 PM |
| Newbie- Where do I start? | javafiend | DIY-CNC Router Table Machines | 7 | 03-01-2008 02:50 PM |
| Single start vs double start ballscrew. | darik | Linear and Rotary Motion | 13 | 03-21-2007 08:53 PM |
