  #25   Ban this user!
Old 10-08-2009, 09:42 PM
FandZ's Avatar
FandZ is on a distinguished road
Ah man, you should keep this thread going. There's a lot of good information in it. If you do start a new one I hope you can move all your build info and pictures till this point to it. When I first came here, reading good build threads from start to end taught me a lot. I'm no fool though, there's still a lot more to learn.
  #26   Ban this user!
Old 10-23-2009, 09:25 PM
Jack000 is on a distinguished road
just wondering, what's keeping the bearing and the butcher boy rollers together? Is it just friction? I'd like to use these for my next build, but wouldn't a strong tug pull it apart?
___________________________
www.carveit.ca
  #27   Ban this user!
Old 10-24-2009, 07:15 AM
GeeksGoneBad is on a distinguished road
Hey Jack
Mine are pressed together using a vise - I'd have to use a hammer to get them out
although I did have some Butcher Boys that were too big and the bearing did fall out - I tossed those... I'd say 75% of the butcher boy bearings I bought were the right size
Check out my projects at www.backyard-workshop.com
  #28   Ban this user!
Old 10-24-2009, 01:38 PM
pencilneck is on a distinguished road
I have a couple of looser fitting bearings as well, but with everything bolted together, the gantry and round rod kind of keeps everything in place so it wasn't a big deal.
I wonder what those "buthcher boy bearings" are made for in the first place.
  #29   Ban this user!
Old 10-25-2009, 09:52 AM
Keep an eye on those 'loose' ones - I did the same thing (thought that they would be OK) but found them to be a source of "flex" when milling some aluminum
New Machine Build- Idea for linear bearing made from 8020 Paulds DIY-CNC Router Table Machines 4 05-13-2009 08:12 AM
Bearing Idea fahque99 DIY-CNC Router Table Machines 10 02-16-2009 06:27 AM
cheap linear bearing idea... billyinks DIY-CNC Router Table Machines 4 04-12-2008 03:21 PM
Crazy linear bearing idea! mvaughn Linear and Rotary Motion 26 08-19-2005 08:07 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
