Just wondering people opinions on the x axis. I have recieved my plans from solsylva and for x axis it has two options for stepper setup. Either a stepper on each side leadscrew(one slaved to other) or a single stepper with a belt that drives both leadscrews at same time.Just wondering what the better option is in this case. I am going to build the 24" x 48" router table and will be mostly doing engraving on acrylic and 2.5d carving in wood all opinions welcome.Cheers |
| The two motors give you double the power, and are easily slaved together in Mach3.
BUT, the downside at higher rpm's two motors can be speed limiting.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Why would it be different? Unless you're talking about 2 motors, one drive. With 2 motors, each with their own drive, you should have the same speed, and double the force. Which, should actually get you a little more speed.
| You wind up with mechanical charactestics that aren't perfectally matched. For example one screw may be leading a fraction at one point verses the the other screw. Or, one screw has more friction in an area. Then you get motor variations to add to that. The real reason to use a dual screw is racking. If your mechanics are such that racking isn't an issue, one motor is more efficient. i.e. two motors developing the same force as one motor won't run as many rpm's as the one motor. More power isn't always better when it comes to steppers as you go up in rpm's. I'll take one G203V and a good motor over two axis of a G540 and two motors any day. And it's the equivalent $ or less when you consider cost per axis of motor, driver, extra power supply load, screw and mechanics.
Can't you just connect the motors in series or parallel? That's what I'd do. Then you wouldn't have any controller discrepancies, and you could run both just as you were running only one. |
| If you want to use two motors, do as ger21 said, sync them via the software. My point was two motors synced isn't the optimum for high speed rapids. And it's both a mechanical issue as well as an electrical issue. Mechanically: I like to use extremes sometimes to make a point. Consider one screw is 10 tpi, the other is 11 tpi, they wont travel very far without binding. Now lets get more practice, realize that all screws have tolerances, one maybe 10.001 tpi, the other might be 9.998 tpi, then factor in that they aren't necessarily linear, one maybe 10.002 for the first foot, then 9.998 the next foot, and the other is opposite in non linearity. What you wind up with is along the length of the travel, mechanical inefficiency. As long as you have plenty of power, it's not a big deal. BUT steppers loose power significantly as you go up in rpm's. This mechanical inefficiency becomes an issue. Electrically: The step sequence of two different controllers isn't an issue, they will be precisely in sync. BUT, motors aren't mechanically perfect. One may move 1.82degrees for a given step the other 1.79 degrees for a given step, so they basically fight each other. At low rpm's it's not an issue, but as rpm's increase it becomes more of an issue. NOW add on to that the fact that steppers naturally resonate. The specific resonance points vary based on motor, rpm and drive methodology. Regardless of wether you have resonance compensation or not, they will fight each other some. Again at lower rpm's it isn't an issue. Bottom line, as you go up in motor rpms two sync'd motors won't behave as well as one motor. The question was which is the best, not wether two motor would or wouldn't work. Two motors do work when synced via software, and work very well. Last point is biggest bang for the buck: One G203V is $150 one motor is $40, one good screw is $40 one good nut is $20 Total = $250 Two axis of a G540 is $145, two motors are $80, two good screws are $80 two good nuts are $40 = $345 not including the cost of a bigger power supply, extra coupler and asundry parts. And the G203V with the one motor will win the rapids race. BUT, if your mechanical arrangement is prone to racking, THEN you are better off with two motors.
#10
| 1. You power off machine; 2. Your kid (or any other person) enters the room and spin one of the leadscrews. 3. You guess what's next. |
#11
I'm curious, how much of a performance hit are we talking here? 5%? 10%? Now, connect the two motors together with a belt, and they'll be fighting each other constantly, which would be a much greater performance hit.
On my router right now, I have my Y axis (single motor) set at 185ipm rapids. The dual motor X axis is set at 175ipm. The reason for that is I have a slightly bent screw that starts whipping and binding in a certain area. I'm fairly confident that when I straighen the screw a ittle later this week, I can get the speed about the same as the Y axis. And it's moving about 40-50 lbs more weight. So I don't think the performance hit of two motors is very great. And, it's a lot easier to use two motors, then build a gantry that won't rack.
#12
| Good point though, with out them being linked, there would be pretty severe consequences. @ pminmo: You have very good points. I didn't take into effect part and motor variations. I don't think the results would be troublesome in a setup, but it is always (very) possible. |
| Need Help!- Mach3 A axis (4th axis) setup? | cadcamslawek | Mach Software (ArtSoft software) | 10 | 01-17-2012 09:23 PM |
| Problem- X4+ 4th axis setup | srbob | Syil Products | 5 | 05-05-2009 08:01 PM |
| 4th Axis Setup Help | Cartierusm | General Metalwork Discussion | 2 | 03-18-2009 11:19 PM |
| Best 4 axis and PC setup ? | gunlocators | Controller & Computer Solutions | 13 | 08-05-2008 03:16 PM |
| Z Axis Setup | musicmkr | DIY-CNC Router Table Machines | 5 | 06-10-2004 12:33 AM |
