#13
The majority of dual motor driven gantry machines built here, are slaved in software only, with no mechanical connection, and work perfectly fine.
#14
| I have seen these machines on the forum and do realize that. Anyway, good luck on your build bluc. |
#15
Different people build from the same set of plans with different results because person A pays attention to detail uses a digital caliper and every detail is right on. Person B, uses yardstick that has 1/16" marks as the finest resolution of scale and gets a completely different acting machine. ![]() So the right answer to the original question depends on all the components the builder has selected, what quality they are and how well that person builds. And most importantly how well the axis tracks without racking.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#16
#17
| This one of mine is wood and over 3', no racking at all. One screw one 280 ozin in motor.
#18
| If you push on one side, it won't move at all?? Actually, I guess if you can tie the two sides together under the table, you can eliminate a lot of the racking. Looking even closer, I can see why you wouldn't have any racking. Are those 1" shafts, or bigger?
#19
Nope, not even a hint of racking
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com Last edited by pminmo; 09-23-2009 at 08:48 AM. |
#20
| To answer the original question: I built one of these, a 24x48. I chose to go with one stepper and the long belt. Why? It is *much* simpler, and simple is good. If I ever want to change that, it is easy to do with only the cost of the belt sacrificed. However, I am very happy with the result (see www.liming.org/cnc for more.) The two rods do not rack, and they never get out of sync. I turn one of them all the time, and the other moves right along with it. There are other things to be concerned about (see above) but this is not one of them. Good luck, bluc, on your build! |
#21
| Yea am building same one and have looked at your build log fair few time I am a bit dissapointed as I cant find the nessasary channel for the gantry here in Australia. Trying to find someone to get some advice on an alternate grade. If cant get aluminium might go to light gauge mild steel or last resort wood. |
#22
| Need Help!- Mach3 A axis (4th axis) setup? | cadcamslawek | Mach Software (ArtSoft software) | 10 | 01-17-2012 08:23 PM |
| Problem- X4+ 4th axis setup | srbob | Syil Products | 5 | 05-05-2009 07:01 PM |
| 4th Axis Setup Help | Cartierusm | General Metalwork Discussion | 2 | 03-18-2009 10:19 PM |
| Best 4 axis and PC setup ? | gunlocators | Controller & Computer Solutions | 13 | 08-05-2008 02:16 PM |
| Z Axis Setup | musicmkr | DIY-CNC Router Table Machines | 5 | 06-09-2004 11:33 PM |
