Hi all, I need some advice for routing/cutting mdf, the problem I have is the the dust which has been cut does not get removed from the cutting site so after a few passes the cutter is recutting the dust and is over-heating, I've even had it smoking ![]() So here is whats happening, Am trying to cut out a shape from a piece of 18mm mdf, am using a 6mm 3flute sprial cutter, am taking 3mm cuts, feed rate is slow due to using 8mm threaded bar 1.25mm thread pitch. So way doesn't the dust get ejected from the cut trench? What is anyone else using? Rob |
| You'll need to blow air into the cut to remove the chips. Also, switch to a single flute cutter. 3 flutes are for very high feedrates.
| oxy gasoline cutting torch - oPetrol cutting torch | denniswang | Product Announcements & Manufacturer News | 6 | 02-20-2010 05:23 PM |
| Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine | stephaniehamer | Laser Engraving & Cutting Machines | 5 | 06-29-2009 04:37 PM |
| Can Watr jet cutting and laser cutting make endmills obsolete? | slashmaster | Benchtop Machines | 24 | 06-18-2009 05:07 PM |
| I need help about cutting heads which apply to apparel pattern cutting machine | sheepgrass | Mechanical Calculations/Engineering Design | 0 | 05-12-2006 02:09 PM |
