  #13   Ban this user!
Old 09-24-2009, 08:55 PM
eloid is on a distinguished road
4 axis
can someone explain how to do a turning ie 4axis in art cam
a simple example please?
  #14   Ban this user!
Old 09-24-2009, 09:50 PM
Khalid's Avatar
Khalid is on a distinguished road
I am also after turning operation in Artcam... I can do indexing but not turning like a lathe...
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
  #15   Ban this user!
Old 09-25-2009, 05:28 AM
CarveOne is on a distinguished road
To do spindle turnings like a wood lathe you just need a regular variable speed motor to turn the stock, and just use the stepper motors for X and Y axis movements. Your steppers would need to be almost light speed to do carvings on high speed rotating spindles.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
  #16   Ban this user!
Old 09-25-2009, 10:14 AM
CarveOne
setup is not the issue of the cnc, may need some help importing the 3d design into artcam, main isuue is using artcam to produce the gcode to cut the turning...need someone to explain I know it can be done.
how...
  #17   Ban this user!
Old 09-25-2009, 11:38 AM
Khalid's Avatar
As Carveone explained...
Eloid you can make a simple vector in X-Y plane... Generate a profiling toolpath... Now the toolpath is in X-Y plan... Now let suppose your Lathe/Indexer is along the X-axis... You have to swap the Y-Axis motor with Z-axis Motor.. and Viola.. Or use G17, G18 or G19 whatever your machine requires..
  #18   Ban this user!
Old 09-25-2009, 11:41 AM
Khalid's Avatar
CarveOne
Can you further explain CarveOne...
Light speed = Speed of Light
or
Light speed = Very slow speed?
I think you mean very high speed...
  #19   Ban this user!
Old 09-25-2009, 10:19 PM
or
Yes, speed of light.
CarveOne
CarveOne
  #20   Ban this user!
Old 09-26-2009, 11:24 PM
info
please anyone have ArtCam Users Guide need last couple of issues page 355 in the current, page 294 in the previous.
  #21   Ban this user!
Old 09-29-2009, 07:11 PM
wood Applique
Ok, i understand most Applique made in artcam use the 2 rail sweep
however there some tricks!! to it for complex shapes attached is a eg i found
someone did in artcam can some please share some tips how the the more complex shaped are formed and anyother tips... for mulitipe leaf etc
see the attached pic i circle the red and green areas i need help with
  #22   Ban this user!
Old 09-30-2009, 11:25 AM
mecanicu is on a distinguished road
CarveOne try this
Try mill wizard addon from artcam 2008 sp 5. there u cand edit in 4 axys or open a new project and there u have some 3d future, or open a new model and in the menu-reliefs-import 3d model for unwrapping u cand import a model and set the exact location......when u import the 3d model in artcam you need to unwrap (transform it from 3d 4axys in a 3d 3axys relief) then u cand set the tool path and machine it with a cnc that support a Y,Z and the X axe swaped with the 4 axe( the rotary table).
Sry for my bad en.....if u have mor question ask me
  #23   Ban this user!
Old 09-30-2009, 11:37 AM
mecanicu sent me pm
  #24   Ban this user!
Old 09-30-2009, 11:41 AM
Originally Posted by eloid View Post
mecanicu sent me pm
Tomorow now i'm leaving home from work.....
MDX-15 ARTCAM totxa ArtCam Pro 15 03-29-2009 12:14 AM
2007 ArtCAM User Group Meeting Sean P Product Announcements & Manufacturer News 0 02-27-2007 09:22 AM
2007 ArtCAM User Group Meeting Sean P ArtCam Pro 0 02-27-2007 09:01 AM
