  #13   Ban this user!
Old 09-21-2009, 08:54 AM
rowbare is on a distinguished road
It almost sounds like the cutter is flexing a bit. Try running the program 2 or 3 times on the same hole to see if it improves after each pass.
Old 09-21-2009, 10:12 AM
ger21's Avatar
If the hole is too big on the first run, not sure how running it more will make it smaller?
Old 09-21-2009, 10:29 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
are you center or spot drilling the holes first ?
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
  #16   Ban this user!
Old 09-21-2009, 10:40 AM
Riceburner98 is on a distinguished road
Originally Posted by Ed Williams View Post
I can't find any play. I'm using a .125 bit. Holes are 20mm.
.125" bit cutting a 20mm hole, sounds like circular interpolation. (you are milling a 20mm hole with a .125" endmill, right?) If so, spot drilling isn't going to do anything for him. Only time I've seen this problem has been from cutter flex on a long-ish endmill, but then the top should be the correct size and the bottom should be *too small* in which case more finish passes would help... If it was flex it would have been happening all along at the same speeds / feeds. If all else is the same and it just started though, no idea....
Old 09-21-2009, 10:49 AM
dertsap's Avatar
Gold Member
Originally Posted by Riceburner98 View Post
.125" bit cutting a 20mm hole, sounds like circular interpolation. ...
missed the 20 mmm
I agree cutter deflection ,
  #18   Ban this user!
Old 09-21-2009, 11:40 AM
It won't make it any smaller for sure but if the hole squares up, then you know that your cutter is deflecting and you can adjust accordingly.
Need Help!- bottom of 3d pocket chaz6966 BobCad-Cam 2 02-23-2009 09:44 AM
Bottom Up approach lsilva Benchtop Machines 4 03-03-2006 11:37 AM
Milling top and bottom? bigvinney General Metalwork Discussion 7 01-28-2006 09:16 AM
Look at my bottom Graham S DIY-CNC Router Table Machines 21 12-14-2004 02:12 PM
Ok so what is the bottom line? WallCrawler CNCzone Club House 8 06-19-2003 09:51 AM
