Old 09-18-2009, 03:59 AM
wern5821 is on a distinguished road
What stepper motors do I use with these electronics?
Hi everyone
For a table top cnc machine I am following the tutorial from Tom Mcwire on instructables but I've noticed he leaves out important info like what stepper motors to use with that particular controller circuits. Can any of you tell me what stepper motor with the right specs I should buy and what is the best website to buy them? Below is a list of the circuits I bought from digi key. Also, do I need to buy wires or is the wires that come with the motors the only wires I need. Any info would be very helpful. thanks
Ref. Qty Description
C1 Cap 1 Capacitor 10 volt or more and about 200 uf
Part No. Mfg. Source Source Part No.
EEU-FC1J221 Panasonic Digi-Key P10346-ND
R1 Res 1 Resistor 1000 ohms
[if your voltage is > 15 volts this should be 1/2 watt or more]
5073NW1K000J12AFX Phoenix Passive Comp. Digi-Key PPC1.0KW-1CT-ND
R3 Res 1 Resistor 100K ohm
ERO-S2PHF1003 Panasonic Digi-Key P100KCACT-ND
Zener 1 Zener Diode [ Voltage regulator for ICs]
1N4735A-T Diodes_Inc Digi-Key 1N4735ADICT-ND
D1-D4 4 Diodes [ to clamp voltage spikes]
1N4004-TP Diodes_Inc Digi-Key 1N4004-TPMSCT-ND
U1 1 IC BCD Up/Down Counter 16-DIP
CD4516BE Texas_Instruments Digi-Key 296-2075-5-ND
U2 1 IC Decoder CMOS BCD-DEC 16-DIP
CD4028BE Texas_Instruments Digi-Key 296-2045-5-ND
Q1-Q4 4 MOSFET N-CH 100V 12A TO-220AB
RFP12N10L Fairchild_Semiconductor Digi-Key RFP12N10L-ND
R2 1 "Lamp Socket [Hldr, Lamp; Wedge; PCB; 23 Series]"
23-35 (PC) Lighting_Components_and_Design ALLIED Electronics 931-2335
Conn. 1 Connector 25 Pin D-Sub Male [You need this to connect to the computer]
171-025-113R001 Norcomp_Inc. Digi-Key 4225ME-ND
Old 09-19-2009, 02:37 PM
amishx64's Avatar
amishx64 is on a distinguished road
You'll need to buy additional wire. The wire on the steppers is less than a foot long.
Can you post the Instructable link?
Old 09-19-2009, 03:24 PM
pminmo's Avatar
pminmo is on a distinguished road
The problem you have is current control. That is a simple full step unipolar driver similar to the tachus42 driver on my website. Depending on the power supply you use, and motors you select you will need to also implement a current limiting ballast resistor. If you built the small mill that goes along with it, then you won't need much of a motor as there is very little performance to be had.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 09-21-2009, 12:52 AM
Jesse B's Avatar
Jesse B is on a distinguished road
http://www.instructables.com/id/Easy...and-Driver-ci/
There it is
Not meaning to threadjack, but I was considering making either the above linked controller, or the above mentioned Tach42 from PMinMO. Which is the better controller? Thanks, sorry again for the thread-jacking
Old 09-21-2009, 08:50 AM
pminmo's Avatar
There it is
They work the same way, same performance issues. Two phase full step, the tachus42 pcb has proven layout. The light bulb current limiting on the instructable circuit is less than desireable and motor dependent.
Old 09-21-2009, 04:06 PM
amishx64's Avatar
If you don't want to use light bulbs: When you pick motors, you'll need to calculate if and what value current limiting resistors you need using the voltage of your PSU and the coil resistance of the stepper.
Oh and BTW, I would probably use a pminmo board layout if I were doing it from scratch.
Need Help!- First time poster/builder needs help with Electronics. (Motors etc) Lapin DIY-CNC Router Table Machines 5 07-17-2009 10:02 AM
Need Help!- Troubleshooting my electronics - can't get motors to move octothorp DIY-CNC Router Table Machines 5 04-29-2009 05:40 AM
Newbie- Stepper controller electronics HighTechRedNeck Stepper Motors and Drives 2 01-16-2009 11:02 PM
quick stepper electronics question keebler303 General Electronics Discussion 4 03-31-2006 08:40 PM
Uni-Stepper & simple drive electronics chronon1 General Electronics Discussion 29 11-30-2005 01:01 AM
