Old 09-16-2009, 01:09 PM
eloid is on a distinguished road
mach3 question?
Is there a beta / trial versions? that is not limited to 500 lines of code....
On a limited budget now...
Old 09-16-2009, 01:45 PM
ger21's Avatar
Mach2 should let you run 1000 lines of code.
Old 09-17-2009, 02:18 AM
MadeInTheShed's Avatar
MadeInTheShed is on a distinguished road
My mach3 stops at 500 lines.
Its not that much of an issue, as 500 lines is a lot of code unless you are programming straight lines for arcs. If I need more than 500 lines, I break the code up into less than 500 line chunks and run 2,3 or 10 codes for the one job.
Mach3 is such a great program that when I can afford it (read when SWMBO is looking the other way) I will purchase it!
Old 09-17-2009, 11:43 PM
clamps is on a distinguished road
Just try EMC 2. It works great. They even have a live CD that will let you run it without installing anything.
http://www.linuxcnc.org/content/view/21/4/lang,en/
I have ran both this and Mach 3. EMC2 will probably get you what you need if you are on such a tight budget.
-clamps
Old 09-18-2009, 12:16 AM
-clamps
you need linx to run it.... dont have to much room on this drive for dual boot
Old 09-18-2009, 12:35 AM
Well that is the thing about the live CD. You don't have to install anything. You don't even need a hard drive in your computer, just a bootable CD-ROM drive.
The Linux environment will boot into memory and allow you to run EMC2 from there.
The only real catch is that your settings won't persist between reboots, but there are even ways around that.
-clamps
Newbie- bobcad mach3 question alex 850 BobCad-Cam 2 08-25-2009 09:24 AM
Need Help!- G-251/Mach3 question alphamail Gecko Drives 0 11-06-2008 04:14 AM
MACH3 Licensing question turbostang Mach Mill 3 05-03-2007 10:15 AM
Mach3 question cosmynnec Mach Software (ArtSoft software) 0 05-01-2006 02:46 PM
Mach3 configure question? dmgdesigns Mach Mill 2 11-14-2005 02:57 PM
