Old 09-15-2009, 12:18 PM
miwms1955@gmail's Avatar
miwms1955@gmail is on a distinguished road
Question Need info on lead screw
I am in the process of getting everything together to build a 2 x 4 cnc router and need some info on a lead screw for my X axis.
How much of a benefit will I get from a 2 start(2 thread) lead screw?
I think there is an increase in speed but is it worth the increased price?
Thanks in advance
Mike
Old 09-15-2009, 01:41 PM
ger21's Avatar
Probably 2-4 times faster. Assuming 1/2-8 2 start acme. Depending on motors and drives, you may even want to go with 1/2-10 5 start. I find the 60" long 1/2-8 2 start screws on my X axis whip badly over 150ipm, limiting my rapids a little.
Old 09-15-2009, 02:31 PM
jsheerin's Avatar
jsheerin is on a distinguished road
I have the 1/2-10 5 starts, ~60" long as well between supports, and I can go a bit faster before whipping - about 250ipm or so. Above that they start vibrating but not really whipping. From theory, you should be able to go twice as fast with the 1/2-10 5 start before whipping. However because of stepper motor torque curves, that might not actually be true depending on what your cutting forces are and where on the force vs speed curve you are running.
From reading chip load information from spindle manufacturers, you'd really want to cut most wood even faster though - more in the 300-600ipm range if you're using 2 flute tools. This seems to be much more easily achievable with rack and pinion setups than screws. I've been looking at converting my router over to that lately for that reason.
Old 09-15-2009, 09:10 PM
I plan on using 2 lead screws for the X axis. Will this reduce the problems with whipping and vibration?
Thanks,
Mike
Old 09-15-2009, 09:18 PM
ger21's Avatar
Thanks,
Mike
Nope. I have 2 screws on mine. Though one of them is bent slightly, which causes more whipping. The 5 start is really the way to go. But you will want at least 300oz motors minimum.
Old 09-15-2009, 10:49 PM
FandZ's Avatar
FandZ is on a distinguished road
Ouch, my best rapid is 68IPM. Gives me a lot to think about for my next build. I haven't cut that much with my router but I haven't noticed any problems cutting at 45ipm.
Old 09-15-2009, 11:01 PM
jsheerin's Avatar
I've had some problems with my bit heating up. The higher chip load is supposed to reduce heat buildup because the larger chip carries the heat away from the cut. As you probably have experienced, if you sit the cutter in one spot, it tends to burn the material. Going faster should reduce that. But if you don't have enough force or power in your router, you have to take smaller depths of cut.
To Mike, I'd recommend getting a motor that has a broader torque curve. For example, the 425oz-in motor from Keling is what I have. It has a lot of low speed torque, but not as much higher speed torque. So at higher speeds, a lower rated holding torque motor with better design will actually have more force.
Old 09-15-2009, 11:12 PM
FandZ's Avatar
I haven't tried taking more than a 1/4 depth inch cut yet. Maybe that is what has saved me but I haven't seen it burn anything. The last time I used it I felt the bit right after it was done and was surprised to feel it was barely over room temperature. I was useing a 2 flute upspiral Bosch bit I got from lowes on my hitachi 2.25hp router. The wood was scrap pieces of boards that I had. Not sure what type. I got a sheet of .75 MDF I was planning on useing next. I hope it doesn't start smoking.
Old 09-16-2009, 03:15 PM
Where would I find a 1/2 - 10 5 start acme lead screw? I have been looking on the internet and the closest I've found is a 1/2 - 8 4 start screw.
Thanks,
Mike
Old 09-16-2009, 03:33 PM
ger21's Avatar
McMaster Carr
  #11   Ban this user!
Old 09-16-2009, 04:04 PM
rbarr110 is on a distinguished road
Thanks,
Mike
Try MSC Direct as well
http://www1.mscdirect.com/Acme-Threa...000000451.HTML
  #12   Ban this user!
Old 09-16-2009, 10:13 PM
Thanks for the help.
Mike
Tags
leadscrew, leadscrews
Need Help!- Lead Screw info Drools DIY-CNC Router Table Machines 1 03-25-2009 07:28 PM
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 05:10 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 12:23 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 09:42 PM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 09:06 AM
