  #13   Ban this user!
Old 09-14-2009, 09:05 PM
FandZ's Avatar
FandZ is on a distinguished road
Originally Posted by jsheerin View Post
No - you don't move the axis with the motors. You just rotate the indicator in the spindle. The assumption is your table surface is flat and plane and thus moving the spindle around in x and y is unnecessary. The longer the arm the indicator is on (and the further away from the spindle's center line), the bigger the errors shown on the indicator. Ideally you would rotate the spindle and the indicator reading would never change as you swept a complete circle. If your z axis is not perfectly perpendicular to your table, then when you compare readings from +x and -x, there will be some difference and you can shim as appropriate. Same for y, although typically you would unbolt things and tap in the alignment in the y direction the way most router are built.
I should have posted my question more clearly. I was asking about the actual surfacing of the spoil board I was wondering if there was a command in mach 3 to do it. Or how most people go about doing it.
  #14   Ban this user!
Old 09-14-2009, 09:08 PM
jsheerin's Avatar
jsheerin is on a distinguished road
Oh. Well hopefully it will help someone else...
I just programmed surfacing a rectangle in my cam program when I first did mine. Once you've done it once, you just reuse the same program later.
  #15   Ban this user!
Old 09-14-2009, 09:18 PM
rlwoodjr is on a distinguished road
That is a fantastic way to check the z axis....
No - you don't move the axis with the motors. You just rotate the indicator in the spindle. The assumption is your table surface is flat and parallel to the x and y axes already and thus moving the spindle around in x and y is unnecessary. If your z axis is out, there will just be ridges or scallops in the spoilboard from surfacing it (how big depending on how far out of alignment the z axis is). The longer the arm the indicator is on (and the further away from the spindle's center line), the bigger the errors shown on the indicator. Ideally you would rotate the spindle and the indicator reading would never change as you swept a complete circle. If your z axis is not perfectly perpendicular to your table, then when you compare readings from +x and -x, there will be some difference and you can shim as appropriate. Same for y, although typically you would unbolt things and tap in the alignment in the y direction the way most router are built.
  #16   Ban this user!
Old 09-14-2009, 10:00 PM
TOTALLYRC is on a distinguished road
Surfacing the spoil board.
All you do is write some g-code to surface (or pocket as my cam software calls it) the entire surface of the spoil board. This is dependent on the travels of each particular machine.
Mike
  #17   Ban this user!
Old 09-15-2009, 01:03 PM
jsheerin's Avatar
Here's an example of aligning some rails:
http://www.5bears.com/cnc08.htm
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
How square is square and how to get there? Roguish Mechanical Calculations/Engineering Design 14 01-31-2008 07:16 AM
Make IH forum for all full sized square column mills... BobWarfield Suggestions for the CNCzone.com site. 6 04-17-2007 02:45 PM
How do you make sure your table top is perfectly square and level jeepn4life Mechanical Calculations/Engineering Design 5 11-25-2005 01:12 AM
How to make Parallel Square Beam/pipe without flat surface ? Calico Welding, Brazing, Soldering, Sealing 8 06-26-2005 08:13 PM
