Hello, I am in the process of designing a gantry-type wood/aluminum/steel milling machine. I intend to build the major structural components out of welded steel sub-assemblies bolted together. The overall machine footprint is TBD, but I do have 6X THK HSR 25 40" rails + various carriages to use in its construction. At this point, I'm contemplating making the machine able to take a 48"X48" workpiece and have 18" under the gantry (yes, I will need to join the rails but I have done this before). My question is in regard to how other builders have ensured that the x-axis rails--the ones that the gantry rides on-- are coplanar with each other. I see a couple problems with this. First, the mounting surfaces for the rails need to be made flat (really flat if you want good accuracy since the rails won't be as stiff as the supports and will conform to them-flat or not). I can probably accomplish this with my mill with some difficulty in several steps as it only has ~18" travel on the long axis. Next, after mounting the master rail against a straightedge of some sort and to the first support, the slave rail/support needs to be squared relative to it. To me, this seems like the toughest part. The easy way that I see to do this would be to bolt/weld the whole assembly together roughly square and have the top surface machined flat. This would probably cost quite a bit although I might be able to get it done as a favor... I have read through everything that I could find here and have not found all that much regarding this topic. One interesting method presented was to shim the rails into flatness/squareness (using a machinist’s level for reference) and bedding them in JB weld. It seems like this would sacrifice some rigidity of the bed due to the flexibility of the JB weld. Might be the way to go though. Any ideas? |
| http://www.5bears.com/cnc.htm This site is a journal, kept while a man built the best and most highly precise homebuilt mill I've ever heard of. He deals with, among many other things, exactly what you're asking. Fair warning...his level of perfectionism is addictive. And, scary! -- Chuck Knight Last edited by chuckknigh; 03-07-2005 at 01:22 AM. |
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| mwp, check out the Thompson site, when using their shafting they recommend laying the shaft on a bed of epoxy that is on the support rail. You can use the same technique to linear rails...unless you have access to a huge mill where you can machine the surface where the rail will be mounted. The next problem will be in adjusting the linear rails so that they are co-planar...fix one rail, and make the 2nd adjustable....I would level the 2nd rail using a rigid straight edge with a machinist level.....unless you have a perfectly straight - straight edge mark the spot where you place the level and where the straight edge meets the linear rail's trucks. |
| How to make them Co planer without a big ass mill. I have 50' of thk rails to mount on my new machine i'm building and need to do it right the first time. Best method would be to haul the different axis's down to the local big ass mill shop and have it done. The base where the x axis slides will be mounted will be 3000+lbs. Not a easy or cheap task. Gotta be a better way.. How would one do this in a small shop with limited tools. Got a good dial indicator and caliper need a machinist level. What else do I need. Don't have parallels or guage blocks. Any ideas. Be specfic please.Donny www.whiterivermfg.com |
#10
| This might help: http://www.lmwatts.com/straightedge.html
#11
| I think the trick on a large machine is to design it so the rails are on a substrate that is adjustable (using shims, as an example). How do the 'big' CNC machine builders do this? Do they rely on precision machining to build the frame of the machine, or do they have an adjustment scheme built into their design? |
| slide/ rail question | 2muchstuff | DIY-CNC Router Table Machines | 13 | 04-14-2005 06:25 PM |
| THK Rail question | chas | DIY-CNC Router Table Machines | 11 | 08-27-2004 01:24 AM |
| Bolt spacing on THK rail? | samualt | DIY-CNC Router Table Machines | 6 | 07-24-2004 07:36 PM |
| Wrong THK rail - Help! | samualt | DIY-CNC Router Table Machines | 10 | 07-17-2004 02:26 PM |
| extending THK rails, rail alignment | Cliff_J | DIY-CNC Router Table Machines | 1 | 05-28-2004 01:09 PM |
