Old 09-10-2009, 10:25 AM
bill south's Avatar
bill south is on a distinguished road
Router Mount Diagram Porta Cable 892
Hey Guys and Gals;
I'm almost finished with a servo driven cnc router project and need to fabricate a mount for the 892 Porta Cable router. I'm trying to source a diagram for the mount(s) to prevent having to re-invent the wheel. I have a benchtop cnc mill with lotz of aluminum scrap from my router build and can do all the machining at home. I can work with most drawing formats having bobcad, alibre and autocad available.
Any help will be appreciated. Please, someone save me some time!!!
As ususal, thanks for all the help. This place is great!!!
Bill from Spartanburg!
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 09-10-2009, 11:02 AM
jsheerin's Avatar
jsheerin is on a distinguished road
K2 sells them - I think they're around $40. If you really want to do it yourself, it's pretty easy to measure the router and draw up a plate. If you don't have the router already (and so can't measure it), I'd recommend something else. I've had bad luck with my 892. My 10 year old 1.5HP Dewalt easily outperforms it.
Old 09-10-2009, 11:13 AM
ger21's Avatar
It's a 3.5" hole in a square plate.
Old 09-10-2009, 03:01 PM
bill south's Avatar
Thanks Guys;
I looked at K2's mount but they are $50 now and I don't want to spend that much on this minor part. Gerry, the 3.5" was the magic dimension and I sketched up a mount in about 5 minutes using K2's pictures but not totally copying his design. Mine is designed around my z axis of course.
jsheerin, I'm kind of surprised you like the dewalt better. I was under the impression that the porta cable was the better router. Well, guess I'll know better the next time. Unfortunately, the PC is already on its way.
Thanks again guys!
Bill
billyjack
Old 09-10-2009, 03:18 PM
jsheerin's Avatar
I can't actually use the Dewalt - it's too short. However I was having problems with my PC and decided to swap in the Dewalt as a sanity check. It cut multiple times deeper at higher feeds without any problems than the PC using the same bit in the same material. Actually I think there's something wrong with my PC - I can't see it being designed to work as it does. But when I took it in to the service center, they couldn't find anything wrong with it, so I'm done with it. I just bought a 3.7kW spindle to replace it. Hopefully I won't have problems with that.
Newbie- Where to mount router? sonicwonder2000 DIY-CNC Router Table Machines 1 09-01-2009 08:34 PM
Need Help!- Need X-Axis cable breakout diagram VF-0 Brush Motor lkenney Haas Mills 3 11-08-2008 07:48 AM
Looking for CNC Router Mount GlacialWanderer Want To Buy...Need help! 1 07-07-2008 02:39 PM
Router Mount wired DIY-CNC Router Table Machines 24 09-29-2005 09:08 PM
Porter Cable Router Motor Mount dowling177 DIY-CNC Router Table Machines 1 04-04-2005 08:40 PM
