Old 09-10-2009, 04:29 AM
kostas1 is on a distinguished road
What spindle should I get...?
I am interested in the 1050W FME milling motor...I want to use it in
a cnc router of 1.5X1m...My cnc router's speeds will be quite high (maybe rapid up to ~480 IPM) and I want to use it at a daily base for wooden
products production(milling figures,sketches in wood, carving some
patterns on doors, make detailed figures for musical instruments
etc...)
Is this spindle able to handle such job?Does it has the desired
power for the tasks I want it?
Or should I look for a better/stronger one? The problem is that I cannot afford a 2.2Kw spindle?I can put up to 200Euros for the spindle....
Thanks in advance,
Kostas.
Old 09-10-2009, 09:59 AM
Kress techinician answer
Here is what a kress techinician told me about this product:
"We thank you very much for your interest in our motor 1050 FME and would like to confirm that
many customers worldwide are using this motor in combination with CNC-machines.
Therefore we would like to confirma that a daily use with this motor in a CNC machine can be
done, provided that the routers speed will be adjusted to the material and the cutting tool.
We hope that this information is useful for you.
Old 09-10-2009, 12:00 PM
Pplug's Avatar
Pplug is on a distinguished road
For the same price of the kress, I would get a Chinese spindle and inverter from e-bay. It offers more power depending on the model and less noise. I have used several kress spindles and the Chinese spindle offer the best "bang" for the buck. They are also easier to get replacement bearings for!
If you are worried about getting ripped off from china, like I was, try e-bay user linearmotionbearings2008. He was reliable and has good products.
Old 09-10-2009, 12:34 PM
I was thinking of this spindle but it is more expensive than kress also...kress costs 139 euros while a 0.8 kw spindlr with inverter costs 355 dollars...it is too expensive...
http://shop.ebay.com/linearmotionbea..._sop=12&_rdc=1
Do you have links to verify your opinion...
Thanks for your answer though...
Old 09-11-2009, 04:44 AM
Hi again,
if I decide to "press" my pocket and think about a chinese spindle, is the 1.5kw version able for such a machine or 2.2kw is the only way?
Thanks...
Old 09-12-2009, 08:42 PM
Pplug's Avatar
I don't think the Kress is going to give you the power you need. I have a 2.2kw spindle and I wish I had more power. I have a 48X96" router that travels at 250ipm. The spindle is a lot more powerful than the PC 3.5 HP router it replaced.
Good luck!
Old 09-13-2009, 05:32 AM
Hi, thanks for the info...
I concluded to 2.2Kw...many of users here use it and they are happy, so will I...
Pplug: How is your machine performing? Do you use 1 balscrew and motor per axis? I was thinking to extend my design to 1200mm X 2000mm...
I already have 3 640oz-inch keling motors, 3 geckos 203V, KL-6515 and C11 breakout board...
Do you have any picture of it?I would be very interested in what is looking for and in its performance...
Thanks.
Old 09-13-2009, 05:40 AM
judleroy's Avatar
judleroy is on a distinguished road
355 us dollars is 243 euros.
Tags
2.2kw, kress, spindle
Feed rates / spindle speeds for HF spindle yngndrw General Metal Working Machines 2 03-21-2009 11:46 AM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 12:11 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 06:51 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 03:49 PM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 11:48 PM
