Old 09-08-2009, 06:28 AM
jz2hs6 is on a distinguished road
4' X - 8' Y (Gantry) Router Table
Hi All,
Building a CNC router table is such a great idea. I've been building furniture for a long time but I'm a better designer than a patient woodworker.
I keep pondering having an 8' gantry that travels 4'. Here's my newbie thinking; The gantry will be heavy due to it's length and extra support to compensate it's span but it's driven by two screws. You will need less screw length; two 4' sections in the X and one 8' in the Y for a total of 16' compared to 20' if the axis were reversed.
I'm not going to dive into such a large bed for my first build. I'll start with a smaller machine to learn from and use it to build a larger one. That brings me to my second question. Can you cut aluminum with a CNC router that was intended for wood?
Scott
Old 09-08-2009, 07:45 AM
ger21's Avatar
Saving 4 ft of screws is not a good enough reason to double the length of the gantry. You'll now need to build an 8 ft long beam that doesn't sag or flex at all. A 4 ft beam would be much stiffer.
Also, When you get over 4ft, you might want to look at rack and pinion. You need much bigger screw diameters for an 8ft screw, and the cost goes up quickly.
Yes, you can cut aluminum. But, how fast you can cut it depends on the rigidity of the machine.
Moving Table, or Moving Gantry? (For Router) Cryptonic26 DIY-CNC Router Table Machines 6 04-20-2011 03:38 AM
open table vs closed-table gantry setups nicanor76 DIY-CNC Router Table Machines 2 04-21-2008 01:35 PM
CMM Gantry Machine as a Router or Plasma table? sbalder General Metal Working Machines 3 09-22-2007 01:44 PM
Moving Table vs Moving Gantry; Dremel vs Router chuckknigh DIY-CNC Router Table Machines 32 03-27-2007 09:48 PM
Conversion to programable independant heads for Gantry Twin head router table ohallock DIY-CNC Router Table Machines 0 04-18-2006 07:20 PM
