Hi all, I just got set up in my new cnc friendly house. YAY!!! I'm in the process of designing my second build and one thing I'd liked to do to save money is to build my own bearing blocks on my current cnc machine out of wood or mdf. I have some 1/2 inch ID bearings and some nuts that fit my 1/2 10 acme screws. I'm trying to figure out where the bolts and washers would go. Is it... bolt, washer, bearing, coupler or bearing, washer, bolt, coupler bolt, washer, bearing,washer, bolt, coupler I'm attaching some pics of what I kind of mean. Also any tips on how to secure the bearing in the block? Should I do a two piece block where the bearing is sandwiched? Should I make a slightly smaller hole and press it in there? Any advice would be great. |
| This is obviously a thrust bearing situation and not just a radial bearing block based on the nuts and coupler... yet you don't list thrust bearings in your position call out. Typically it would be the coupler, locking collar, washer, thrust bearing, washer, bearing block assembly which consists of a cover plate, radial bearing, & bearing block, washer, thrust bearing, washer, & finally locking collar. I'm taking a guess and I'm going to say you are looking to use the nuts in place of locking collars but unless you double them up as jam nuts a singular nut on each side of the radial bearing can't restrain the bearing block assembly unless you are going to jam nut the whole shebang on the radial bearing inner race and let the radial bearing handle the thrust forces...??? OR am I looking at this all wrong... which is a chronic condition with me? Senna |
Hrmm... I didn't think of making my own lock collars and didn't know they would be needed. I'll guess I'll do that too! I was just looking for a simple solution useing what I have. I'm trying to make something like this but with 1/2inch id bearings http://cgi.ebay.com/3-Aluminum-Beari...d=p3286.c0.m14 After reading your post I'm thinking I could get away with, coupler, lock collar, washer, bearing, bearing block, washer and lock collar. No nuts. |
| Here's a diagram of what I recommend for my bearing block setups, including parts you can buy from McMaster Carr or MSC to give you thrust bearing capacity as well. All designed for a 1/2" bearing: http://cncrouterparts.com/product_in...products_id=58 If you can make the block and cover, you'll be able to replicate this. It's worth the couple of bucks for the thrust bearings and shaft collars to keep things running smoothly. Ahren www.cncrouterparts.com |
| Skate Bearing Blocks? | thebluedirt | Linear and Rotary Motion | 12 | 02-08-2009 07:59 AM |
| Skate Bearing Blocks -- a journey with RTV | GreenvilleDave | Linear and Rotary Motion | 7 | 02-04-2009 05:50 PM |
| Adjusting ballscrew bearing blocks | sansbury | Benchtop Machines | 1 | 11-30-2008 09:45 AM |
| 2- Micromill bearing blocks and mounts. | radicooldude | Employment Opportunity | 3 | 01-13-2006 09:51 PM |
| RFQ Simple Aluminum Bearing Blocks | b0gh0s | Employment Opportunity | 8 | 12-23-2004 03:57 PM |
