Old 09-04-2009, 10:19 AM
Marmot_Militia is on a distinguished road
How to: Spindle support bearings for Rotozip?
Machinists,
I am making a high speed secondary spindle for my cnc mill. I have a Rotozip that I'd like to use.
My concern is deflection of the endmill in aluminum. Or basically the lack of rigidity of the stock bearings. Has anyone built a spindle extension that can be supported by another bearing?
My thoughts were to get a piece of drill rod and chuck it in the RZ's collet then buy a second collet and machine the end to basically make it another collet. The bearing support would then be added to stabilize the drill rod and therefore the end mill.
Any other ideas?
Regards,
MM
Need Help!- Bmc ball screw support bearings JWC HURCO 7 09-27-2008 09:56 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
slideway support rails + oilite bearings colormecnc Linear and Rotary Motion 2 07-13-2007 03:03 PM
ROTOZIP as Spindle. esmiller DIY-CNC Router Table Machines 17 04-10-2005 02:25 PM
