  #13   Ban this user!
Old 03-08-2005, 09:38 AM
dumpster's Avatar
dumpster is on a distinguished road
cnc2k,
These leadnuts put my cnc router at less than .0005 backlash, I use the 1/2-8 (2 start) screws. My 1" travel indicator can't tell me any closer than that really... I have backlash comp turned off in Mach2 (finally). I feel these leadnuts are zero backlash but can't guarantee it, you also have to take into account other factors that cause backlash such as endplay of the motors (if direct drive), pullies, belts, mounts, etc... plus the actual acme screw has a tolerance, usually .009 per foot.
Tim
  #14   Ban this user!
Old 03-08-2005, 10:41 AM
Xerxes's Avatar
Xerxes is on a distinguished road
I managed to build pretty good nuts from brass. Idea is little bit similar to that derling nut but without spring loading.
See it here:
http://www.students.tut.fi/~kontkant/jv2.php.html
Last time I adjusted the nut, I got less than 0.005 mm backlash (0.0002").
  #15   Ban this user!
Old 03-08-2005, 07:13 PM
Woodie1 is on a distinguished road
Can you give more details on how you made the nuts?
  #16   Ban this user!
Old 03-09-2005, 12:44 AM
dumpster's Avatar
Larry, check your email.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Anti backlash nut design nakchak DIY-CNC Router Table Machines 13 09-06-2008 05:32 AM
anti backlash nut? sixpence DIY-CNC Router Table Machines 13 07-18-2007 01:51 PM
anti backlash nut hpghost Linear and Rotary Motion 3 05-15-2005 08:16 PM
Leadscrew backlash nut issue. jaydee116 General Metal Working Machines 5 12-13-2004 06:57 PM
