Old 03-03-2005, 10:07 PM
rocks101 is on a distinguished road
Ball Screw Backlash
How much backlash is there on a 5/8 nook industries ballscrew, non preloaded. Would it be better to go with a 1/2"precision lead screw, at 10 tpi and make my own anti-backlash setup.
Old 03-04-2005, 07:43 AM
Bubba's Avatar
Bubba is on a distinguished road
rocks101,
First off, what do you plan to use this on? There are tables on critical lengths vs speed etc that you have to look at. Secondly, the change between the typical 5 TPI and 10TPI will also affect speed. Thirdly, the coeficient of friction between ball and lead screw is great. This will affect the required power to move the axis.
Why not use the ball screw and make a pre-loaded nut??? I did and it was fairly easy to do. Zero Backlash.
To possibly answer your origional question, I was told by Roton their rolled ballscrew single nut had a typical .006" backlash!
Art
Old 03-04-2005, 09:35 AM
Thanks for the info Bubba, I plan to use it on a 3 axis router im building, im really leaning twoard the ball screw, but i dont want to buy to ball screw nuts to eliminate backlash, I heard you could use slightly bigger steel balls.How would this affect the performance of the ball screw Any suggestions appreciated.
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 09:27 PM
Ball Screw Identification BeerFizz Benchtop Machines 2 04-07-2005 11:28 AM
Ball screw backlash options Stevie General Metal Working Machines 22 11-08-2004 12:32 PM
Need help with Ball Screw Choice samualt DIY-CNC Router Table Machines 5 09-06-2004 08:02 AM
