now that I have my first cnc up and running, I have been planning on my second build. I like to use my cnc to make custom aluminum part ie gear box etc. Looking to design 4x9 cutting area similar to the shopbot prsalpha 120 http://www.shopbottools.com/prSstandard.htm but with U frame design with a adjustable table top surface... similar to the CNC Mill, Artisan for doing coloums ( frame design) http://legacywoodworking.com/products.cfm?product=304 Im thinking about using Industrial racking to lock into the U shape bed frame.. Anyone use the industrial shelving for a table support ? The the racking system will not be the cnc support or ridgid frame the U shape tube steel frame will do that. |
These aren't industrial but they sure are solid. Can't bend em at all. To top it off they were about $3 at Home Depot. This is shown in my build thread (see my signature), but I'll re attach a picture. Edit: Well shoot. I don't know what U frame you are talking about or whatever, but I hope that helps. |
if not well over 1000 pounds with the steel tube frame and mdf table top and gantry ( 4x9 feet cnc) As for the u frame table look at the legacywoodworking link there frame is designed for larger woodworking pcs and a lathe along the y axis which require a drop bed or very long z axis.. |
| no problem the racking is heavy duty stuff, but you still need a welded frame to prevent vibration and racking movment in the gantry and rails.... Im was planing to use the racking system, only for the table taop ie to lower the bed table height |
I did some googleing around for Industrial racking and for the price, I'd look into 80/20. You mentioned wielding, if that isn't a problem for you than why not just weld some steel tubes up? I just don't see the value in useing industrial shelving though. Now if you have a cheap source, please share, then that's a different story. |
| I was looking into the 8020 stuff as well. It seems perfect for what I want, but I can't find anywhere in the UK or europe that a similar product can be easily purchased. I've found many websites of companies that sell this type of thing but they all seem orientated more towards bulk buys. Anyone have any suggestions? |
#10
let say i needed to drop my table 16" for my cnc lathe head stock option to cut (9 foot long 12 inch diameter columns?) for straight fluted, rope design, tapered square etc columns.. cant be done with a weld frame... The neat thing about the perferated framing rails, they are all keyed to except light weight support rails... (and they cheap and strong) oR let say i need to change over to my plamza cutter setup, And I need to raise the bed up 12" from this height... the table is fullly adjustable. lets say i want to do some foam cutting ie hotwire and I want cut out 3d object out of 36" cube .... just remove the complete table, and have the entire center free and clear no obslicale... just sitting on the U shape frame members... the two Y driven axis need to support by a weld U shape frame to prevent vibration, movement / racking and side to side movement on such a big machine,,, and added stiffness to you machine. If you did not weld the super structure you machine would be out of square every time you remove the table ... your gantry would not be true and the drive system would bind because all of the above... The idea is to think out side the box, leaving you with the options to machine, plazma, carve, make foam molds ie anything you need. |
#11
| via plasma or lazer cut... |
#12
lengths ie 9 feet.. the only place i can see it very usefull is for linear guide way bearing it make aligning them a breaze.... for X y axis and the gantry |
| Newbie- CNC Table support equipment question(s) | race_hemi | CNC Plasma and Waterjet Machines | 5 | 04-08-2009 08:17 PM |
| water table and support steel weight? | Crayola | CNC Plasma and Waterjet Machines | 1 | 02-10-2007 10:51 AM |
| Industrial laser table recommendations please! | kennected | Laser Engraving & Cutting Machines | 1 | 01-27-2007 02:40 AM |
| Industrial Vacuum table | osdhillon | DIY-CNC Router Table Machines | 6 | 10-24-2005 05:38 PM |
