Old 08-29-2009, 07:30 PM
LazyMan is on a distinguished road
Spindle on/off
I am confused about what is needed to turn a spindle on and off. I understand how a router can be turned on and off via relay. Is it the same for a spindle/vfd? Do I need a vfd speed controller?
Old 08-29-2009, 11:21 PM
TOTALLYRC is on a distinguished road
A VFD needs a start/stop signal and some sort of usually analog input to vary the spindle speed. My Hitachi sj200 can also be programed in a multi speed mode where based on several different relay type inputs, it willl give say 6 preprogramed speeds.
A g540 from gecko has the analog output needed to drive a vfd or you can get an analog "module" from several BOB suppliers.
Mike
Feed rates / spindle speeds for HF spindle yngndrw General Metal Working Machines 2 03-21-2009 10:46 AM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
