Old 08-26-2009, 08:22 AM
rjfurness@bigpo is on a distinguished road
Hold Downs/Vac Table for Balsa
Hello All,
my second router is intended to have a vacuum table made for it, however having read the various threads about vac tables I am not so sure that is a suitable approach to take.
I will be cutting balsa wood from 1/16 in to 1/4 in almost exclusively. Reading that MDF is porous and leaks air, I am assuming that balsa would also be very difficult to hold down with a vacuum.
I will be cutting parts out so I will be doing through cuts 100% of the time so I expect I will be adding to my air leaks throughout the process.
Any recommendations on the best way to hold down balsa sheeting?
Jason
Old 08-26-2009, 09:27 AM
tmbg is on a distinguished road
you may be able to do it with vacuum, but you'll need a high flow system... on porous materials you can't hold vac so you just have to pull LOTS of air through it
Old 08-27-2009, 03:22 AM
Thanks tmbg,
I think I will proto some small MDF box with the vacuum cleaner to get a sense of the issue.
Any thoughts from anyone else with experience will really help.
Jason
Show Me Your Hold Downs Mr.Chips DIY-CNC Router Table Machines 27 01-22-2010 08:30 PM
Hold Down/Table Style options douglasco DIY-CNC Router Table Machines 1 01-23-2009 08:49 PM
New T Hold downs installed wcarrothers1 DIY-CNC Router Table Machines 3 12-07-2008 12:57 PM
Vacuum hold-downs and rotational problem about the z axis cpcp Work Fixtures and Hold-Down Solutions 5 12-08-2006 07:02 AM
Wet hold downs CNCadmin General Metal Working Machines 0 12-18-2004 12:20 AM
