  #13   Ban this user!
Old 03-02-2005, 02:20 PM
kywoodwrkr is on a distinguished road
text transfer
I don't want a temporary printing.
I want the print to remain on the piece.
Be cause if I'm as slow at assembling these parts as I have been in getting the machine put together, I'll forget which part was what.
I'll be taxed even with some verbage.
What I'd like to end up with is a part cut out ith an assembly part number on it.
Nothing elaborate.
I think possibly a ball point pen refill assembly in the unpowered router would probably work. Should be able to use a 1/8" chuck possibly even.
Thanks.
DaveP
Old 03-02-2005, 05:01 PM
ger21's Avatar
Route numbers into the parts, and just route out the parts.
Old 03-02-2005, 05:36 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Something like this, maybe?
http://www.cnczone.com/forums/showthread.php?t=5988
  #16   Ban this user!
Old 03-02-2005, 05:51 PM
pen25 is on a distinguished road
when cutting why not leave bridges and route in a cut sheet #. assosiate the cut sheet # with the template or assymbly drawings so if you have multiple parts in one sheet you dont knock it out until its ready to be put together just like in a model.. if you want to # it and dont want to damage the peice and if the cutter is fine enough you can route the # or part # below or in room.
  #17   Ban this user!
Old 03-03-2005, 08:58 AM
parts graphics
Pen25,
I just want to be able to print/write or other wise note on each piece what its part number is.
Person using them may not have a clue how, when or etc they were made.
I'm anal about making things as fool proof as possible for the end user.
Comes from over 30 years of installing computer systems in the end user environment.
Sol,
Considered plotting pens but figured they would bleed on the softer woods, chestnut, balsa etc.
I did save your picture however.
I'll try and talk my local blue print shop out of a couple older pens for experimentation.
Thanks again all.
Every idea has parts which are usable.
If not here, then on the next question. :-|
Thanks.
DaveP
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 10:46 AM
Simple cheap CNC router mwalach DIY-CNC Router Table Machines 7 10-28-2005 07:08 PM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 05:34 PM
