Hey guys - I cut out a part from plastic (King Starboard to be exact) and my Y axis walls are perfect, byt my x axis are like scalloped - hopefully you can see it in the picture what would cause something like this? I programmed depth cuts of .02 with a .25" bit and even did a finishing pass at .05" - was a brand new bit too thanks for any ideas! Jamie
__________________ Check out my projects at www.backyard-workshop.com |
| I have Acme 1/2"-10 leadscrews with homemade delrin nuts when the router is traveling on the shorter axis is when I get the rough sides - and actually I've removed the cables (which were to prevent racking and worked quite well) after some modifications I've made - there are no pictures yet of those mods up on my site - but basically I'm using better bearings on all axis and also a steel bar across the bottom with bolts all the way through (instead of the t-slot connections that I find are kind weak)
| I would think that is either racking or flex in the Z axis or gantry. Was this cut at a slow speed or feed? If so, you might try speeding up the cut to see if it makes a difference. If not, then try a slower cut.
__________________ Lee |
| yep I tried a few different feeds and speeds - the slowest my router will go is about 8000 rpm and I started at 6ipm and all the way to 30 ipm with no difference - I also tried a faster RPM on the router at the different feeds with no difference either I will try some tests to see if it's racking - I know I have just a little bit across the gantry but I was thinking that wouldn't affect a cut going across - but I will clamp that sucker down and see if that removes the scallops... if it is then I'll just reinstall the cables and pulleys (pocket door tech)
| Need Smooth Finish Please | Hoover | WoodWorking | 3 | 01-18-2008 05:47 AM |
| Smooth motion required high feed 3 axis surface milling | cncjoy | Fanuc | 11 | 10-13-2007 01:03 AM |
| text not smooth? | DEW | BobCad-Cam | 4 | 04-05-2006 08:20 AM |
| Axis movement is not smooth | bgolash | Stepper Motors and Drives | 6 | 12-19-2005 03:36 AM |
| Smooth as silk | Stevie | TurboCNC | 4 | 04-24-2005 10:46 AM |
