Old 03-01-2005, 10:05 PM
playinsteel is on a distinguished road
Using drive components from an impact printer
Hey everybody,
I have been busy disassembling an Oki Pacemark 3410 impact printer. Here's what I found inside. 2 - Shinano Kensho STH-53D101 Stepper Motors 1.8 deg/step, 5.0V, 0.8A, six wires. 1 - Shinano Kenshi DX050-020E2N01 which appears to be a 24V DC motor with an incremental encoder built in. There is also an Oki stepper KHL42SL14A, 11.7V DC 34 Ohm 7.5 deg/step six wire.
Are any of these useable for a first attempt at building a CNC table? My plan is to start small, get this thing working, and then build larger as the need arises. I was also curious about the boards from the printer. Can they be used to drive the steppers? I am looking at one that was for the 5V steppers...OKI BTFD 3PU4003-3072. It appears to be fed with 115 ac as it has an SLA4061 driver chip.
I'd Appreciate any feedback.
Using a large drive on small motor? murphy625 General Electronics Discussion 0 03-11-2005 05:23 PM
Help! ...no drive movement CRFultz General Electronics Discussion 4 01-21-2005 08:30 PM
Good DC motor and drive JRoque General Electronics Discussion 11 01-02-2005 10:38 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 11:09 PM
Creating a chopper drive with discrete components using the L297 tpworks General Electronics Discussion 15 05-31-2004 01:04 PM
