Old 08-17-2009, 11:45 AM
piperCNC is on a distinguished road
First CNC Using J. Kleinbauer Pipe Dream Plans
I've started building my first CNC router using John's Pipe Dream Plans. Anyone else done this recently. I've finished the rails and the trolley. I'm having a hardtime getting the floating nuts right. Any suggestions on how much side to side and up and down the floating nut should have and what do you do to try to obtain consistencey form one floating nut to the other. Any other words of wisdom are appreciated. There is an amazing amount of information in this group.
Thank you,
Chris
Old 08-18-2009, 10:11 PM
Jason Marsha is on a distinguished road
The floating nut idea I avoided and lined my axis and nut up as best as you can but running the machine all the way to one side lining up, run it all the way to the other and repeat the process. When you are finished the floating nut should not be needed.
How does kleinbauer slides work ? FlyDave DIY-CNC Router Table Machines 1 04-13-2009 10:36 AM
Kleinbauer, plans got a question jem1043 DIY-CNC Router Table Machines 2 01-12-2007 12:52 PM
emt conduit, galvanized pipe or black pipe? JohnG DIY-CNC Router Table Machines 5 05-21-2006 08:24 PM
