| Hello, I have been slowly gathering parts for my first CNC build and need a little help determining a good lead-screw & motors for my needs. I already have rails, bearings & complete Z-axis, frame will be made entirely of 8020 t-slot. X rails = 4' & Y rails = 2', max travel has not been determined yet but I am not too worried about having as much as i can get... my parts to be cnc'd will be small. applications are PCB & small aluminum cases, need to be as precise as possible, the aluminum cases will hold optics and have very small tolerances. I have gone through alot of threads and am not too much clearer on determining a proper motor & lead-screw combo. I am not pinching pennies, so I would rather spend a little extra to do it right the first time. Can someone recommend a good ball-screw & backlash nut with proper pitch, & a set of motors to match? I dont mind reading and learning myself, but everything I have come across is specific to the authors needs... which primarily seems to be wood, and of course different lengths. Any help is greatly appreciated ![]() p.s. - I do have a nook catalog but its mostly greek to me :/ |
| Have you looked at www.pdjinc.com ? |
| How fast do you want to cut and rapid at? And what are the tolerances you're looking to hold?
| wow thanks for the fast reply's! I'm not really clear as to those ger... i dont know how to translate the cut/rapid to an actual work time. I have seen other PCB makers go for with tolerences of .01 i believe? that will also suit my aluminum case needs. Im more concerned with accuracy than speed, however i also dont want to wait 24 hours for a 3" square box to be completed |
| .01", or mm? if inches, anything will do that. Most people building Joe's 4x4 machines are using 1/2-10 5 start acme, and DumpsterCNC AB nuts. much cheaper than Ballscrews, and will still give good performance. As for motors, it really depends on how much you want to spend, and how much force you need. A keling G540 package will work. http://www.kelinginc.net/CNCNEMA23G540Package.html If you want more speed and power, I'd go with Nema 34 motors and Gecko G203V's. 400-600 oz motors, rated around 6 amp will get you the highest speeds.
| That's one thing in not sure on is how much force it sill take to cut soft aluminum... I know pcb's take near nothing. I looked at the G540, but looks like it will come with 2 more motors than i need since i already have a Z axis completed. Maybe im understanding it wrong but it says 4-axis, so im assuming 4 motors? any location i can read more about those leas screws? Thank you for your help ![]() also, i took a look on my micrometer and .005 or less would be preferred |
| ooh ger, I just read a post from you in another thread about making sure to have 'home' switches. I realized i completely forgot about that, are those supposed to connect to the drivers? or are they just an emergency crash switch that cuts motor power? I am using the allegro bi-polar chopper from pminmo.com http://pminmo.com/ss3977/ss3977.htm |
| You already have the drives for all the axis?
#10
If you buy it from Gecko Drives it comes with no motors. They only sell the driver modules. If you buy it from another source that sells the G540 you have the option to buy a 3 or four motor bundle. Home switches allow the software to run the motors to a known position that is detected when the three switches open as the motors reach that predetermined position. Home switches can be set up in software as home and limit switches in combination. Limit switches tell the software to stop the motors before running into the end of mechanical travel and potentially causing damage. There are software limits also, and are set to define a "box" that will define how far the motors can go. This can be the only limits, or it can be used in addition to the limit switches as two levels of avoiding damage. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
#11
I just ordered the G540 directly from http://www.geckodrive.com/for $210.00 (They are currently having their customer appreciation sale). You could order 2 motors from http://kelinginc.net/ for $39 or $49 each which would give you a very nice package for about $300. The G540 also includes connections for limit switches as well as outputs for relays. Incidently, I received my G540 (in Canada) about 26 hours after I placed the order. I was impressed!!! Ayjay
__________________ Don't sweat the small stuff - and there ain't no big stuff! |
#12
| You won't go wrong with the g540's. I am very impressed with them and the company service. You can see my build log for more about the 540's at www.liming.org/cnc I just wish they were that cheap when I bought them! |
| Problems with motor stalling due to motor/lead screw alignment | Bimmerkc1 | DIY-CNC Router Table Machines | 3 | 01-24-2010 06:12 PM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 08:42 PM |
| Making a coupler between motor and lead screw | nikolatesla20 | Mechanical Calculations/Engineering Design | 8 | 07-30-2005 01:05 PM |
| Problems aligning motor with lead screw. | SCCoupe | DIY-CNC Router Table Machines | 11 | 02-15-2005 06:33 PM |
| coupling motor to lead screw ideas? | fyffe555 | DIY-CNC Router Table Machines | 4 | 09-15-2003 11:18 AM |
