Old 02-28-2005, 11:52 AM
Nonoriginal is on a distinguished road
How about this motor/controller set-up?
Been reading tons and the information here is amazing!
This is what I have in mind for my Motor/driver/power supply set-up.
Motor: Automation direct bipolar 276 oz./in. $39 http://web3.automationdirect.com/adc.../STP-MTR-23079
Drives: Salem bipolar stepper drives and power supply $100 for each axis
http://www.salemcontrols.com/products/sc125ms.html
http://www.salemcontrols.com/products/psupplies.html
Should be $139 for each axis + shipping = $427 + shipping
Am I missing something?
Old 02-28-2005, 12:48 PM
ger21's Avatar
You can get a Xylotex 3 axis board for $150. It uses the same chip as the Salem board, so I'm guessing the performance is similar.
Old 02-28-2005, 01:00 PM
buscht's Avatar
buscht is on a distinguished road
Nonoriginal, You are missing a few things.
You need the motor cables to go with the Automation Direct motors. I think that they are about $10 each.
But if you want to use the Salem Controls you will also need their breakout board and a parallel cable from the computer to the breakout board. Add another $35 total.
Old 02-28-2005, 01:10 PM
ViperTX is on a distinguished road
Well the specs. for their power supplies are incorrect that is milliamps not amps. So a 24 VDC supply at 2.5 amps X 3 = $120. Hmmmmmm....you need an enclosure to stuff the controller and power supplies. If you go with a different controller you'll probably need a different connector for Salem's power supplies.
Old 02-28-2005, 09:21 PM
Ok, I was in a hurry... 15 min. break at work...of course I will need the cables!
Thanks for the reminder about Xylotex Gerry! I would assume the performance is similar as well... I will investigate further.
I'll keep searching for power supplies...maybe even break down and buy Xylo's control box with power supply.
$150+$80+power supply+misc cables = drivable 276 oz/in bipolar steppers.
I can live with that!!!!!
Old 02-28-2005, 09:40 PM
ger21's Avatar
A lot of Xylotex users use power supplies from MPJA. Here's a 28V for $39.95 http://www.mpja.com/productview.asp?product=15367+PS
Old 03-01-2005, 10:49 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
The motors you list are 2.8 amp motors, and the A3977 based drives like the Xylotex and Salem are only 2.5 amps max, so you will not get full torque from these drives.
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Rapid to (# set by Parameter) What's yours? Scott_bob G-Code Programing 8 07-13-2009 08:05 AM
Add a second set of rails to X axis..need advice. bgolash DIY-CNC Router Table Machines 5 05-31-2005 08:11 PM
Running a set number of parts? Shizzlemah AjaxCNC Control Products 2 05-02-2005 07:47 PM
How to set up Tool Offset in MACH2? High Seas Mach Software (ArtSoft software) 7 09-09-2004 01:54 PM
