Old 08-15-2009, 06:08 PM
Drools's Avatar
Drools is on a distinguished road
Carve out not follow outline.
I downloaded a dxf file from http://mydxf.blogspot.com/ when cutting the file I only do the outline and not carve it out like in the picture.
I use LazyCam to inport the dxf and generate the gcode.
Must be a setting I'm missing...
Old 08-15-2009, 09:04 PM
ger21's Avatar
Sounds like you just need to learn how to work with LazyCAM. There's a new manual for it here.
http://www.machsupport.com/forum/ind...c,12078.0.html
Old 08-15-2009, 09:21 PM
Drools's Avatar
Gerry are you talking about the free version of LC or the licensed version? I think this is called pockets in LCam and I'm pretty sure it is turned off in the free version. Maybe there is a way in AutoCAD to do what I need or maybe some other program.
Old 08-15-2009, 10:38 PM
ger21's Avatar
OK, now I understand what you're saying. You got the design in the middle, but it didn't remove all the material. Right?
Sure, you can do it in AutoCAD. Just draw a bunch of lines inside the design where you want the bit to clear it out. I'd offset the outline slightly inside (just over half the tool diameter), then use the array command to create a bunch of parallel lines, and trim them using the inside offset.
Follow the money dynosor Environmental & Alternate Energy 56 11-04-2007 04:33 AM
Pointer to follow tool path. Kiwi BobCad-Cam 1 07-27-2006 10:03 PM
Software to follow a spline continuosly fsalla General CNC (Mill and Lathe) Control Software (NC) 2 09-22-2005 07:01 PM
Follow Up Of My Cnc Put Together Now chris69randy DIY-CNC Router Table Machines 16 04-16-2005 02:40 AM
Please follow the rules CNCadmin BobCad-Cam 0 07-27-2004 09:12 AM
