Old 08-14-2009, 12:45 PM
MBG MBG is offline
MBG is on a distinguished road
Back to building
Okay.. after my first table I scratched that idea.
Now, I am back to the drawing board.
Anybody have any cnc plasma blueprints?
Old 08-14-2009, 02:27 PM
tmbg is on a distinguished road
I'll be drawing some after I finish my mini-router... Maybe we could do a group design
Old 08-14-2009, 07:54 PM
MBG MBG is offline
Okay!.
I am looking for a 4x4 table
What are you planning on what size?
Old 08-14-2009, 11:27 PM
4x4 is what I had in mind as well.
What do you have in mind for linear bearings and drive systems?
Old 08-15-2009, 08:03 AM
MBG MBG is offline
THK bearings?
From what I remember I was going to go "slides" I am not sure it is a while ago.
I wanted servo motors though. I know they are a lot more money then steppers.
I might be building this machine for overkill. I am not sure.
What about you?
Old 08-15-2009, 08:07 AM
MBG MBG is offline
But to be honest with you.
I might be happy with just running steppers making an el cheapo one for the first machine to learn.
Do you know the plasmaCNC machines? Those have steppers and seem to run just fine.
Old 08-15-2009, 09:10 AM
Servos vs steppers almost doesn't matter. It's so easy to switch between the two once it's running. I'll probably start with steppers because I'm familiar and comfortable with them, and they're cheap.
As for linear bearings, THK rails are great, but they're VERY expensive unless you just work around whatever you can get on ebay. Plus, THK bearings are incredibly strong, but there are no cutting forces on a plasma table, so that might again be overkill.
I was thinking about maybe experimenting with skate bearing trucks on flat bar for that machine. Probably drive it from one side with either a screw or a belt, and use a cable arrangement to keep the gantry square.
Old 08-16-2009, 02:52 AM
arizonavideo's Avatar
arizonavideo is on a distinguished road
For the Z you can always find a short LR on ebay for less than $30. You only need one cart and rail.
For the Y you might look at this place.
http://www.automation-overstock.com/...ts.asp?cat=101
I have used them and they are fine. A single 15mm 1200mm rail and cart is about $100.
For the X perhaps some V grove wheels would work OK.
http://www.cadcamcadcam.com/v-groovewheel2.aspx
Old 08-16-2009, 11:28 AM
MBG MBG is offline
For my last build I was thinking of using skate bearings also.
I agree with no forces and the THK being overkil.
I will be in atlanta next week. We should meet up.
Newbie- think back to V18 MailleMas BobCad-Cam 0 12-16-2008 11:21 PM
Welcome back Larken Larken 4 03-17-2007 08:35 PM
Back to building and need advice rcrabb DIY-CNC Router Table Machines 19 10-19-2006 08:24 PM
Lie Back And Think Of Oz WallCrawler CNCzone Club House 4 05-11-2004 10:30 PM
