I'm not really sure if I'm even calling them the right names, but I was wondering what the advantages and disadvantages of each design. (In case I am using the wrong words, for belt drive I mean using the motor to move a belt that moves the ?gantry? and screw is using the motor to turn a lead/ball screw) |
Screws: Keep in mind there are several types. Bottom-feeder variety is all-thread, then ACME with a nut, then Ball-screws. PROS: - simple construction (no gearing necessary) - rigid and reliable - acceleration limited by steppers only (no stretch) CONS: - Can have considerable backlash unless steps to avoid it are taken - Inefficient (stepper power wasted) - More difficult to achieve high rapids with steppers because of decreasing stepper power with RPM - Can whip (vibrate) at high speeds (gets worse with length) Belts: Again, many different kinds. I'm assuming you mean a timing belt set-up which directly drives the axis via a pulley. PROS: - Very efficient - Can have long runs with minimal impact on design (no whip) - Very fast rapids achievable (useful with laser cutters, plasma, etc. where excessive cutting force isn't required. CONS: - Can be more expensive to implement - More complicated drive mechanism - Backlash dependent upon belt tension - Can rebound at higher accelerations and stretch with heavy cuts. Limits the useful cutting speed. - Need to be replaced with wear Lest one of the more experienced members read this and deliver me the internet equivalent of a slap upside the head, the above is my understanding based upon limited experience. YMMV. And remember, search is your friend. There is a wealth of info about this topic already on the zone. |
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| Acme Thread, Ball Screw Or Belt Drive for Laser Cutter/Engraver? | pyrofx | Laser Engraving & Cutting Machines | 5 | 04-08-2009 03:59 AM |
| Need Sherline Belt & qestion on X2 Belt Drive? | Oldboy | Benchtop Machines | 12 | 03-06-2008 12:42 AM |
| Belt driven screw ? | tomcat47 | Linear and Rotary Motion | 10 | 01-29-2007 10:20 AM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 11:23 AM |
